Installing an Electric Starter on a 1993 TW200E
Results 1 to 10 of 18
Like Tree48Likes
Thread: Installing an Electric Starter on a 1993 TW200E
    Junior Member brucelathrop's Avatar
    Apr 2017
    5
    Hey Everyone !
    I'm a newbie with this forum, and I have a 93 TW200E.
    The bike has only a kick starter, and I want to know if I can easily and cheaply add an electric starter to it. Can you give me some specific advice?
    I guess I need a parts list with part numbers if available.
    Thanks!
    BL
    Valencia, CA
    littletommy, Ken and jtomelliott49 like this.
    Pleasanton, CA
    5,740
    Hi Bruce and welcome to the forum!
    I was under the impression that all TW200's were made with an electric starter included. Does your bike have an electric starter, but it just doesn't work? Or is it completely missing?
    Thanks,
    Brian
    Spokane, Washington
    17,378
    Welcome!!
    1st John 1:9
    John 3:16
    John 3:17
    Apr 2017
    5
    Thanks, Brian!
    My only has a kickstart. I do not believe it every had an electric start.
    I need a list of components necessary to add the electric starter.
    Can you or anyone help?
    Thanks!
    BL
    Spokane, Washington
    17,378
    1st John 1:9
    John 3:16
    John 3:17
    Spokane, Washington
    17,378
    What happens when you push the little start button on the right side of the handlebars?
    1st John 1:9
    John 3:16
    John 3:17
    Apr 2017
    5
    Starter Switch
    I do have a little red toggle switch surrounded by a black casing. But nothing happens when pushed.
    I would like to see a photo of where a starter should be located on this bike.
    The previous old owner of the bike told me it is only a kickstart, and I think I may be missing the necessary components.
    Thanks for the help.
    BL
    Senior Member UncleRandy's Avatar
    Feb 2015
    Alaska
    165
    Welcome to the forum Brucelathrop-here all your magical TW wishes will come true. All you need to do is add the elbow grease.
    Would you be able to provide pictures of your bike for us to look at? That will give us an idea of what you have and where to start helping you. A picture of the front of the engine (below the tank) and even your right side handlebar switches will help us diagnose your situation and provide recommendations. FWIW - the starter switch on the right side of the handlebars is not a toggle, it is a spring-loaded, Gray push button underneath the toggle. Ooops! Thanks Brian!
    littletommy, TW-Brian, Ken and 1 others like this.
    Pleasanton, CA
    5,740
    Quote Originally Posted by brucelathrop View Post
    BL
    Here is what your electric starter should look like.
    Here is where your electric starter should be located.
    Here is what your electric starter button should look like.
    Mar 2015
    Ynys Môn
    4,586
    The red toggle switch you refer to is the “engine run” or “kill switch” – toggle it forwards towards the headlight to turn the engine off – toggle it down (or back) towards the tank to allow the engine to start
    The electric start is activated by a simple spring loaded button located immediately below this red toggle – on the TW is came in a few different varieties – either in TW-Brians excellent pic three of post 9 – or it may look like the pic posted below -
    (For a bigger pic, right click on the picture – “open in new tab”)
    On some TW’s, the electric start will not work if the kill switch is set to “off” ……..
    Welcome to the cruise …….
    - Hidden Content
  1. Replies: 10
    Last Post: 09-02-2016, 05:59 AM
  2. New member with his 2006 Japanese TW200E..!
    By indika666 in forum General Discussion
    Last Post: 03-16-2014, 09:12 PM
  3. Quick question about electric starter? Thoughts?
    By Dooly842 in forum Technical Help
    Last Post: 03-05-2014, 06:38 AM
  4. Electric starter problems
    By zj_hummel in forum Technical Help
    Last Post: 11-03-2012, 06:24 PM
  5. Inside the electric starter
    By Rainman in forum Technical Help
    Last Post: 09-25-2011, 02:10 PM
