air filter oil?
Results 1 to 8 of 8
Like Tree25Likes
  • 1 Post By jim
  • 4 Post By scotti158
  • 3 Post By UncleRandy
  • 2 Post By jim
  • 5 Post By jim
  • 5 Post By RockyTFS
  • 4 Post By vanillagorilla1
  • 1 Post By TopPredator
Thread: air filter oil?
    Senior Member jim's Avatar
    Indio, CA
    100
    air filter oil?
    Just cleaned my air filter and used 10/30 to oil it. Any problem In doing so? The original oil seemed a lot more viscous and blue in color.
    littletommy likes this.
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    May 2013
    Groton, NY
    2,663
    You should use foam air filter oil. It's tackier to capture the dust and dirt particles better, also stays on the filter better, IMO.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member UncleRandy's Avatar
    Feb 2015
    Alaska
    164
    Hi Jim, No. there is absolutely no problem with the oil you used on your air filter.The original was probably Yamaha brand. The trick is to be sure there isn't too much on the foam. You'll know if you find a puddle in the box!
    And Scotti beat me to the response-and he's right, air filter oil is tackier and stays in place-less susceptible to changes in temperature. But, if you don't have any-what you used will not hurt anything.
    Indio, CA
    100
    Yep I figured there was a reason it was so tacky.
    cowboyjeff and littletommy like this.
    Join Oathkeepes.org
    Indio, CA
    100
    Quote Originally Posted by UncleRandy View Post
    I rung it out. There was some of the original oil pooling up in the box. Anyway thank you two for the quick response.
    Join Oathkeepes.org
    Hailey, ID
    3,308
    There is absolutely nothing wrong with using plain old 10W30 oil to wet your filter.
    However, you may find it much easier and much more effective to use this: No-Toil Filter Maintenance Kit 2 Pack - Motorcycle Superstore
    It is much more tacky than plain oil but also much easier to clean off the foam element since it is biodegradable.
    I have found that it only needs cleaning and replacement half as often as regular dino oil....good stuff. Wash it in the sink with the cleaner...you will be appalled at the amount of dirt going down the drain!
    My two pack lasted five years. My foam element is still the original....7 years and 14,500 miles.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    792
    no toil kit hands down. I keep one in the bike and one in a zip lock clean and dry. I oil it and swap them out very often. that way im ready with a clean one at any time.
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. sold to a new home 11-24-17
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content for sale
    Jun 2014
    Bel Air Maryland
    4,169
    I also use the No-Toil Filter Maintenance Kit.
    cowboyjeff likes this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
  1. engine oil in air filter compartment
    By beltaine in forum Technical Help
    Last Post: 02-07-2017, 07:38 PM
  2. Foam air filter oil / cleaner.
    Last Post: 03-31-2016, 07:29 AM
  3. TW air filter oil
    By Explorer in forum Technical Help
    Last Post: 09-12-2015, 03:15 PM
  4. Anyone using Rock oil on air filter?
    By Holdnon72 in forum Technical Help
    Last Post: 04-21-2014, 07:10 PM
  5. What do you use to clean & oil your air filter?
    Last Post: 11-02-2012, 09:00 AM
