new front tire
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Like Tree76Likes
Thread: new front tire
    Senior Member lugnut's Avatar
    Apr 2017
    alliance ohio
    217
    new front tire
    I just ordered a new front tire and tube. I went with the Shinko 241 4.0-18 like everyone here seems to like. My question is, how hard is it to change the tire and tube out? I have not done this since I was a kid. I also purchased ride on fluid as well.
    Apr 2012
    Out West
    3,059
    my fav front tire you'll love it !!!
    "It's Like Warm Apple Pie"
    Senior Member DARIVS ARCHITECTVS's Avatar
    Nov 2016
    Ramsey, MN USA
    106
    Answer: a bit of a struggle, but well worth it. You'll need at least two tire spoons, some soapy water, a new inner tube, and ten minutes to watch a YouTuvbe video on how to change a motorcycle tire. You slip the slip the first bead over the rim, insert the new inner tube and fish the stem through the hole and hold it in there with the nut. Where you have to be careful is when you use the spoons to slip the second bead onto the rim without pinching the inner tube and tearing it. Use the soapy water to wet the bead to make it slip over the rim edges easily. The Shinko 241 is not as wide as the DeathWing, but grips wet road much better. You can corner in confidence.
    Fred, littletommy, lugnut and 3 others like this.
    DARIVS ARCHITECTVS
    (Darius the Engineer)
    1944 DKW NZ350-1 11. Panzerdivision
    2003 BMW R1150GS Adventure
    2010 Yamaha TW200 (cuz it's cute)
    18,853
    Good choices lugnut, a winning combination for most terrain.
    lugnut, jtomelliott49, Ken and 2 others like this.
    6,987
    I was apprehensive when I first tired it after having not done it for 40 or 50 years. Get some decent tire irons -- don't use screw drivers -- and it will all come back to you.
    Watch this 3 part video.
    Tire Changing Part 1 | Transworld Motocross
    Tire Changing Part 2 | Transworld Motocross
    Tire Changing Part 3 | Transworld Motocross
    lugnut, Tweaker, Ken and 1 others like this.
    Dec 2015
    San Diego
    1,864
    Its not too bad the front is pretty easy. There are some good youtube videos on how to do it. Buy some good spoons. I got a set like these from motion pro but its your choice on tools. Make or buy a set of rim protectors I marked up my nice black rims with out them. I used windex for the lube. A bead buddy might be nice. I didn't use one.
    Here is a good youtube video, its a back tire with rim lock which we don't have but the principal is the same.
    https://www.google.com/search?q=moto...eABBREQgTYI_gM
    May 2013
    Groton, NY
    2,663
    I good tire stand helps. If you don't have one, get the wheel up off the floor on a workbench, picnic table, or something like that.
    lugnut and cowboyjeff like this.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,395
    I hadn't changed a tire in 40 years, like many others, and I managed to do ok if you don't count the missing paint off the edge of the rim
    lugnut, Tweaker and cowboyjeff like this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Mar 2015
    Northville, MI
    779
    Bead Buddy is a a nice plus (I just did two tires wirh it). It is definetly worth the $20-$40 most shops charge. I would put a new rim strip on as well, while your in there. A decent changing stand would make it a no-brainer! Watch the videos and it will be a breeze!
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
    Apr 2017
    alliance ohio
    217
    Got the new tire and tube and mounted it...piece of cake! Now all I have to do is figure out my air pressures in front and rear!
  1. Front tire
    By Michael Bryce Winnick in forum General Discussion
    Last Post: 12-01-2015, 10:55 PM
  2. TW204 front tire and rear stock tire
    By jgaff in forum Performance and Customization
    Last Post: 06-07-2015, 01:37 PM
  3. Big Tire BW200 Rear Front Tire
    By Beauew in forum Performance and Customization
    Last Post: 05-04-2015, 05:48 PM
  4. FS: CO - Shinko SR244 front tire and Bridgestone TW34 rear tire
    By Nicholast in forum TW200 Classifieds
    Last Post: 12-06-2014, 10:02 PM
  5. Best front tire for Wide Front Tire mod?
    By RiskEverything in forum Performance and Customization
    Last Post: 06-02-2014, 07:26 AM
