Mixture screw trouble
Results 1 to 10 of 18
Like Tree41Likes
Thread: Mixture screw trouble
    Member xicarro's Avatar
    Dec 2016
    Truckee Ca
    60
    Hi everybody, here I'm again trying to get some help/advice.
    I was doing a major carburetor clean up and I have decide to replace the mixture screw to be sure everything is clean and good working condition.
    It was set approx. 2 1/4 turns out so I started to unscrew it out and just 3 or 3 1/5 it began to get really hard, I know there isn't other way out so I had no other option to use all my hand power for a few turns until the last few threats it became smooth again and it came out.
    Now is when I have the problem, the new screw or even the used one refuses to go back all the way in. It starts nice and smooth but it gets to the point that doesn't want to go in anymore, I'm destroying the head with the screwdriver and I know that's is not bottoming in, the head is almost flush with the carburetor edge so if I open 2 1/2 turns out from there the head sticks out. Both screw are identical length!
    Does anyone had this situation?? The carburetor thread looks fine to me. I put a drop of oil and it didn't help at all. When I pulled it out I saw that the O ring got smashed so I don't get what's going on. I will really appreciate if anyone has a suggestion to put that little bugger back in place.
    Thanks a lot
    Daveed
    6,957
    It sounds like the o-ring is to big.
    This is about how it should look:
    Inserting it upside down the head of the screw with the o-ring should slip in -- add a drop of oil to make it easy.
    Good luck.
    Mel, cowboyjeff, Purple and 1 others like this.
    Dec 2016
    Truckee Ca
    60
    The screw doesn't go in even without o-ring, washer and spring.
    18,588
    I would carfully inspect both threads for any damage or debris before very carefully trying to chase both sets with correct tap and die. Confirm everything is clean since it sounds like the old screw had to plow through something fouling the female threads. Smashed O-ring on the new mixture screw hints of some remaining obstruction like aluminum shaved from the female threads when the original mixture screw was forcedly removed.
    6,957
    Maybe some junk stuck in the hole.
    Take a bright light and look into the hole. Hopefully it is something you can remove.
    This is where the tip of the screw sticks out when the screw is bottomed. Maybe you can see something here?
    Fred, cowboyjeff and Purple like this.
    Dec 2016
    Truckee Ca
    60
    The hole is clean. I think Fred has the right answer though the problem i don't know how to clean the female/carburetor thread. I guess I will have to find the way to tap it.
    cowboyjeff likes this.
    18,588
    Problem is an un-modified tap will likely bottom out before cleanng up all the threads, plus may generate it's own shavings that will also need to be removed. May have to cut off some of the tap's tapered tip. Perhaps just a normal straight cut bolt of the right pitch carefully screwed in could locate, if not improve, the problem area if it is in the female threads.
    A demtal pick might also be able to chase down the threads to identify any irregularity and possibly clean up threads. Good luck, a frustrating dilemma.
    Dec 2016
    Truckee Ca
    60
    I'm back on business Fred!!
    I couldn't find any bolt of the same thread pitch so I had to be creative. Using a Camelback hose cleaning brush and air compressor, patiently I cleaned up the carburetor thread. It goes all the way in pretty smooth , the only thing is when it passes the 2 1/2 turns out gets kind of loose, I don't think should be a major issue or I will have to re install a plug so I don't mess with it any more!!!!!
    Thanks
    Mar 2015
    Ynys Môn
    4,550
    Don't know if you guys have "PTFE" tape over there - solves a few problems keeping loose threads in place ......
    littletommy, Ken and cowboyjeff like this.
    - Hidden Content
    Spokane, Washington
    17,260
    I think we call it Teflon tape here.
    Purple and Ken like this.
    1st John 1:9
    John 3:16
    John 3:17
  1. Idle Mixture Screw O-Ring
    Last Post: 09-24-2016, 11:18 PM
  2. Air fuel mixture screw
    By brandonjohnson33 in forum Technical Help
    Last Post: 01-24-2016, 06:05 PM
  3. Setting Idle Mixture Screw
    By Welder in forum Technical Help
    Last Post: 07-31-2015, 02:49 PM
  4. idle mixture screw 4+ turns out?!?
    By a_frye in forum Technical Help
    Last Post: 11-28-2012, 04:35 PM
