XT225 Clarke Tank Reversal to Stock
Results 1 to 5 of 5
Like Tree9Likes
  • 1 Post By frozenteedub
  • 4 Post By TW-Brian
  • 2 Post By joeband
  • 1 Post By littletommy
Thread: XT225 Clarke Tank Reversal to Stock
    Junior Member frozenteedub's Avatar
    Apr 2017
    Calgary, AB
    4
    I bought a 2009 that has the XT225 Clarke tank conversion and would like to switch back to stock. I am not really in need of the extra fuel as I just use it to boot around for errands, and the yellowish tank with the white and black body doesn't look the best. I have the original tank, but none of the original parts to mount it. The service manual doesn't seem to include an exploded diagram with the tank mounting parts in it. I am wondering what the size of the stock mounting grommets and brackets are? Any help would be appreciated... also don't mind trying the hockey puck hack in reverse for the mounting grommets if I knew what size to cut them.
    littletommy likes this.
    Pleasanton, CA
    5,682
    Welcome to the forum!
    Here is a link to a schematic that shows the stock mounting parts.
    Yamaha Motorcycle Parts 2009 TW200 - TW200Y FUEL TANK Diagram
    The rubber damper pucks (Item #4) just push onto posts on the frame. You may still have some of the rear mounting hardware (Items # 5-10). If not, someone here may be able to help you out.
    Hope this helps,
    Brian
    Nov 2011
    norcal nutjob
    3,305
    here's the method i used to put my tank on, just reverse the process.
    https://tw200forum.com/forum/performa...t225-tank.html
    as it shows i had to trim my posts about 1/2" on either side, and grind down the rubber pucks. depending on how they mounted it it shouldn't be too hard to reverse, just get new rubber pucks and push them out a bit. the rear mount should be stock.
    you will probably also need new side plastics, or figure out where to zip tie them as they need to be trimmed to fit with the xt225 tank.
    littletommy and frozenteedub like this.
    Spokane, Washington
    17,260
    Welcome to the forum!!
    Quote Originally Posted by frozenteedub View Post
    frozenteedub likes this.
    1st John 1:9
    John 3:16
    John 3:17
    Apr 2017
    Calgary, AB
    4
    Hope this helps,
    Brian
    Thanks! Looks like the stock parts that are still on the bike were cut/adapted to fit the Clarke tank so I just ordered new parts for $35 + shipping.
    If anyone in Alberta is looking for the Clarke XT225 tank I am happy to give you a deal!
  1. Installing a Clarke XT225 tank
    By Guitarman in forum Sticky threads
    Last Post: 10-04-2018, 06:16 PM
  2. Need help mounting a stock metal XT225 Tank on my TW....??
    By Werloc in forum Performance and Customization
    Last Post: 08-13-2017, 04:41 AM
  3. Replaced the stock tank with a Clarke, now how to ...
    By RDW in forum Performance and Customization
    Last Post: 08-26-2016, 06:52 PM
  4. WTB Stock XT225 Tank
    By ActionDeath in forum TW200 Classifieds
    Last Post: 03-24-2014, 07:38 PM
  5. FS: Clarke XT225 4.1 gal gas tank
    By d-nix in forum TW200 Classifieds
    Last Post: 12-09-2012, 09:38 PM
