Idle issues
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Like Tree48Likes
Thread: Idle issues
    Member Waymore's Avatar
    Apr 2017
    Payson, Utah
    72
    Idle issues
    My 92 I recently bought has been having idling issues. I bought it and it wouldn't even run unless it was fully choked. I pulled apart the carb and rebuilt it. Night and day difference. I replaced the boots between the carb and the engine and the air box. I also cleaned the fuel tank and added an inline filter. Today I changed the oil, filter, and spark plug. I noticed a difference but it will still only idle for about 5-10 minutes max and then dies. It seems to struggle most of that time too. I also should note I adjusted the mixture screw to the factory 2 1/2 turns out. I live in Utah around 4500 ft above sea level. Could being slightly out of mixture be the problem of this? It seems more like it's struggling for fuel than air but you would think at my elevation it would be the other way around?
    Senior Member Deepseadan's Avatar
    Sep 2016
    So Cal
    287
    More than likely your pilot jet is plugged again. One of the most common things people do is clean or rebuild their carb but don't clean or flush the fuel tank which is the source of the problems. Take your tank off and flush / wash it. I use a hose with a sprayer and flush it a bunch of times. Then take fresh gas and pour a half gallon in and swish it around. Empty the gas and let it dry out. Then change the fuel line and add a fuel filter. Clean the pilot jet again and you can at least eliminate the fuel system from the cause of the bad idle.
    Sent from my iPhone using Tapatalk Pro
    Current bikes 2016 KTM 500 EXC, 2016 Yamaha TW 200
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    Waymore, I to live in Ut, same elevation, Both mine 89, and 91 run and idle perfect, just like Deepseadan said its most likely the Pilot Jet or the Pilot Circuit.
    When you clean that Jet you got to make sure you can not see anything when looking thru it. Both mine I could see thru them but there was a like spider web in the middle of them, I must of cleaned them 4 or 5 times before I finally pushed a small wire thru them and they ran perfect after that. I think its the Ethanol that make the web looking thing. It looked to me like it was meant to be there too.
    BkCntryCrwlr likes this.
    Apr 2017
    Payson, Utah
    72
    I just don't see how they could be the problem? I cleaned and sprayed the tank out while I was rebuilding the carb, replaced the pilot screw and jet, and the main jet and nozzle. And then I put in a new hose with an inline filter in it. I then put a brand new tank of ethanol fuel in the tank. That's why I do t see how it could possibly have gotten dirty. That's why I changed the spark plug. Maybe I need a new carb?
    Dec 2015
    San Diego
    1,857
    The other thing that causes bad idle is an air leak in the intake boot. I know you put new boots on could it still be leaking there? Or maybe check your float level. Did you over oil the air cleaner? Or is it dirty?
    Nov 2013
    West Jordan, Utah
    207
    On my 91 I got a blockage in the Pilot passage Im pretty sure, I was just where your at with the same issues, I gave up on my self and took the whole bike to 2 different so called experts, both of them thought they had fixed it, no way! they just did not no how a Tw 200 purrs when its running right. I wasted a lot of money and time, I ended up buying a new Yamaha Carb.
    Now I don't even have Ethanol Gas in the same Barn as the Tw's.
    fishguy likes this.
    Nov 2013
    West Jordan, Utah
    207
    Waymore its a good thing I don't live as close as you do to Rocky Mountain Atv, I would be in the poor house.
    Apr 2017
    Payson, Utah
    72
    Oh believe me I am! I've been in there about everyday since I bought the bike!
    cowboyjeff likes this.
    Feb 2013
    Missoula, MT
    908
    Did you remove the petcock assembly and clean or replace the in-tank screens? Also: "It only idles for 5 to 10 minutes"? Why do you need to have it sit and idle for so long? I either ride my TW or shut it off.
    cowboyjeff and Cornelis like this.
    Apr 2017
    Payson, Utah
    72
    I did not remove the petcock. And I don't need it to sit and idle for long periods of time. But I think it should be able to of need be.
  1. charging issues
    By crankyankee in forum Technical Help
    Last Post: 06-16-2015, 07:49 PM
  2. Replies: 12
    Last Post: 02-04-2015, 09:34 AM
  3. 87 CDI Issues
    By keithert in forum Technical Help
    Last Post: 01-19-2013, 06:35 PM
  4. 2005 carb issues, slow to idle down
    By MrDNA in forum Technical Help
    Last Post: 10-02-2011, 05:28 PM
