Fuel in Airbox
Results 1 to 7 of 7
Like Tree15Likes
  • 1 Post By EVH
  • 3 Post By EVH
  • 3 Post By RockyTFS
  • 3 Post By EVH
  • 5 Post By rbm
Thread: Fuel in Airbox
    Junior Member EVH's Avatar
    Apr 2017
    15
    Fuel in Airbox
    I have a brand new 17 tw200, has about 200 miles on it. I noticed when I went to check the air filter that there was some fuel in the bottom of the air box, nothing was pouring out but you could see it there. Could this be from not turning the petcock to off when its not in use ?
    Ken likes this.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    Yes. No offence intended but I simply can't understand why people in general don't, some refuse to, turn the petcock off. You're asking for trouble if you don't. Do yourself a favor and check the oil for gas.
    Apr 2017
    15
    I guess I'm not used to having a carb bike. I'll start shutting it off and I'll change the oil just just to be safe.
    Thanks for the info.
    fishguy, Dryden-Tdub and Ken like this.
    Hailey, ID
    3,310
    If you transported the bike without turning the petcock off, the jiggling will cause the float needle to let gas into the carb, where it can enter the airbox and/or the cylinder. That needle and seat should not leak on a brand new bike. But you need to change the oil anyway if you haven't done so (and for Lord's sake just clean the filter, not buy a new one!!!). I have left my petcock on many times when my bike is sitting in the garage and never had a problem....but I probably will someday.... I did have a big problem with gas pooling on the floor of the trailer once when I forgot it on a wash boarded road, though!
    Dryden-Tdub, Ken and admiral like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Apr 2017
    15
    I did change the oil and it smelled of fuel, so lesson learned turn off the valve.
    rbm
    rbm is offline
    Jan 2011
    4,300
    Quote Originally Posted by EVH View Post
    Glad you figured it out before a catastrophic failure! Hope everyone else dose before it bites them in the a$$. (Damn, I'm starting to sound like qwerty....)
    TW-Brian, Dryden-Tdub, Ken and 2 others like this.
    Frosty Hollow
    12,979
  1. Fuel pouring out of airbox + running lean
    By travelrider73 in forum Technical Help
    Last Post: 04-16-2017, 06:36 PM
  2. Fuel in airbox
    By i82much in forum Technical Help
    Last Post: 04-15-2017, 08:28 PM
  3. Replies: 7
    Last Post: 08-28-2016, 02:30 PM
  4. AirBox access
    By azbusmo in forum Technical Help
    Last Post: 05-24-2013, 02:19 PM
  5. Old airbox boot.. new airbox boot.. still too short
    By silverhead in forum Technical Help
    Last Post: 05-10-2013, 12:36 AM
