Original OEM Tool Kit Photo
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree72Likes
Thread: Original OEM Tool Kit Photo
    Member captainkettel's Avatar
    Apr 2017
    Sequim WA
    32
    Does anyone have a photo of an original OEM tool Kit. I have a 2012 TW200 that is missing. I will probably just build up a kit to my liking/needs but would like to see what the OEM kit looks like... Found a old thread with a picture... but the photo was no longer available.
    Ken likes this.
    Dec 2015
    San Diego
    1,857
    Here ya go. 2014 kit.
    Ken, 1911garand, GaryL and 6 others like this.
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by captainkettel View Post
    You can buy the tool kit new for $27
    Ken, Tweaker, cowboyjeff and 3 others like this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,997
    Quote Originally Posted by Tweaker View Post
    Nice picture of the real junk tools provided! I suppose $27 is not a bad deal and the kit might get you out of some of the jams we might have out in the field but I have never once opened the tool kit while working on my TW in my garage with a real tool box of good quality tools.
    1987 Yamaha BW350 Big Wheel
    Senior Member BkCntryCrwlr's Avatar
    Mar 2014
    Boise, ID
    416
    I have never even thought of using my tool kit. However, if those are real JIS drivers they would come in handy at times. I'll have to test them out one of these days.
    You can't see it if you're not out there living it!
    '94 Rainbow Warrior - not so rainbow any more - Clarke XT350 tank, Lizrdbrth's seat mod, Beer Trap Pegs, Ricochet skid plate and more.
    Going through withdrawals, sold my other two TW's, down to one....Uhggghhh! Hidden Content
    Dec 2015
    San Diego
    1,857
    BCC they are JIS and I have used mine from these kits until I bought some on Amazon.
    Jun 2013
    Forestburgh, NY
    7,997
    JIS is a highly protected trade name for Japanese Industrial Standard. Here in The US they are called Cross Point if you can't find JIS. If you have a Fastenal store in your area they normally have Cross Point bits in stock and you need size 1, 2 and 3. Using a regular Phillip's head driver on a stuck TW screw and you probably end up needing a new screw because you rounded the head.
    Gary
    Jan 2015
    Fair Oaks, Calif
    500
    Gary
    Darn rights! Had to replace the outer seal for the outer case bearing. The screw that retains the outer bearing plate in the stator and drive gear housing is one of them JIS screws. I have never in my life seen a screw so frickin tight... I did not have a JIS driver to fit... Rounded out the head with a standard philips... Motor tooled to a straight slot and used my impact driver.... WWWWWoooowwww!
    Jim
    Jun 2013
    Forestburgh, NY
    7,997
    Quote Originally Posted by jtstdub View Post
    Jim
    We sure have heard this plenty here. Here is yet another tid bit to pack in your tool box. Phillip's head screw drivers are a disaster on JIS screw heads but JIS or Cross Point drivers work very well on Phillip's head screws and maybe even better than the Phillip's head drivers.
    Senior Member arrowsmith's Avatar
    Missouri
    670
    The big box end wrench works great for removing oil drain plug.
    TopPredator and Moabman like this.
  1. Replies: 19
    Last Post: 08-03-2015, 08:12 AM
  2. TW Tool Kit
    By bruisr in forum General Discussion
    Last Post: 09-28-2014, 08:48 PM
  3. What's in your tool kit?
    By JGillespie in forum General Discussion
    Last Post: 04-24-2014, 09:52 PM
  4. Tool Kit
    By OurDee in forum General Discussion
    Last Post: 01-05-2014, 04:56 PM
  5. Tool Kit
    By scotti158 in forum General Discussion
    Last Post: 05-14-2013, 03:35 PM
