Changing the chain and sprockets and have a couple of related questions ...
Results 1 to 5 of 5
Like Tree7Likes
  • 2 Post By vanillagorilla1
  • 2 Post By Tweaker
  • 1 Post By TopPredator
  • 2 Post By RDW
Thread: Changing the chain and sprockets and have a couple of related questions ...
    Senior Member RDW's Avatar
    Nov 2013
    Oregon
    174
    I was hoping I'd have this done today but it looks like it'll be 5 or 6 days waiting on parts.
    Is the neutral switch something that should be replaced while the the cover is off?
    If so, where is a good source to order it?
    When I ordered the gasket and O-ring kit I thought it would include the shifter seal but I guess I need to order it too. Hopefully be able to order it from the same place that sells the neutral switch?
    I've got the oil cooler on the bike. Where are people buying the replacement O-ring for the oil cooler? (It seems to be a bit smaller then the stock O-ring)
    The outer counter shaft seal screws are frozen. I attempted to use an impact gun with a #3 tip but it didn't work and stripped the heads. Frustrating. Any suggestions besides picking up a set of screw extractors? Not even sure they would work anyway.
    Thanks,
    2013 TW200---2007 XT225---2014 CB500X
    "Everyday is a school day"
    Senior Member vanillagorilla1's Avatar
    Nov 2013
    yakima wa.
    792
    I wouldnt worry about the shifter seal or the neutral switch unless you need to replace them. If you were gonna buy them and you werent gonna buy them locally Id buy from rockymountainatvmc.com. The oring for the oil cooler should be the same. I have an OEM one in my oil cooler.
    When I stripped out two of those screws I just drilled the heads off, removed the plate, gently tapped on it, and backed it out with a pair of needle nose pliers.
    RDW and cowboyjeff like this.
    93 tw. running like clockwork
    225 6 speed complete!
    82 honda gl500 silver wing. sold to a new home 11-24-17
    03 ducati monster 800sie. full rebuild and a danger to the public Hidden Content for sale
    Dec 2015
    San Diego
    1,857
    RDW did you use a #3 phillips or a #3 JIS bit? Just know that all screws on the TW that look like phillips are not Phillips but JIS. Japanese Industrial Standard a different head.
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by RDW View Post
    Thanks,
    Stripped heads, frozen bolts... it's endless when working on TWs. I had no idea how many tools I would need when I started restoring my 1988 Black Widow. Here's some pictures of what I call me War Chest. Study it closely because I needed all these tools.
    https://tw200forum.com/forum/technica...ures-tips.html
    Also be careful tightening the sprocket screws they strip easily. Torque is extremely important on these soft screws.
    jtstdub likes this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Nov 2013
    Oregon
    174
    Quote Originally Posted by Tweaker View Post
    No, I used the standard number 3 even though I know it's a JIS. It seemed like a tight fit. I have a JIS hand driver, but none for the impact gun.
    That's what I get for being impatient and unprepared :-)
    jtstdub and Tweaker like this.
  1. Replies: 37
    Last Post: 11-16-2016, 05:12 PM
  2. Back on a TW, couple questions....
    By Mexicant in forum Technical Help
    Last Post: 01-10-2015, 03:35 PM
  3. Couple of questions
    By c.salt in forum General Discussion
    Last Post: 06-17-2014, 01:21 PM
  4. 2 simple questions Throttle cables and air box related
    By Berryrider in forum Technical Help
    Last Post: 05-01-2014, 06:03 PM
  5. Possible noob here, couple of questions
    By Pigdog in forum General Discussion
    Last Post: 09-30-2010, 07:45 PM
