Brake light not working or stuck on all the time
Results 1 to 7 of 7
Like Tree5Likes
  • 1 Post By Dryden-Tdub
  • 1 Post By Xracer
  • 1 Post By Fred
  • 2 Post By Gerald
Thread: Brake light not working or stuck on all the time
    Junior Member Gerald's Avatar
    Aug 2014
    saskatchewan
    11
    Is there a common problem with the brake light staying on or not working at all on a 2006.
    Apr 2014
    Dryden NY
    6,343
    Quote Originally Posted by Gerald View Post
    No. If it was staying on I would suspect the switch that is connected by a spring directly above the rear brake pedal is dirty/muddy. If it is not coming on at all it could be the light itself or wiring.
    Tom
    cowboyjeff likes this.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,786
    You also have a switch on the front brake too.
    18,853
    You also have an adjustable bolt at the base of rear brake pedal that needs to be adjusted properly to prevent brakes from dragging. Such a maladjustment would also activate brake light switch.
    Aug 2014
    saskatchewan
    11
    Thks for all the advice and I found the stop bolt lock nut came loose and the stop bolt came out pushing the rear brake pedal out.
    Dryden-Tdub and Fred like this.
    18,853
    Yeah, that was my guess since it has happened to me too. Locknut vibrates loose. Also that bolt head can get cupped after repeated braking over the years, especially if you really lean on the brakes. I looked at several other TWs in Moab that were a few years old and all had their adjustment bolt heads hammered into almost a cam like profile from repeated blows from the brake pedal. I installed a new flat headed bolt at that time to restore nice liberal adjustability, no dimple and lobes like on the old worn bolt head.
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,484
    I just went through the same scenario. Kept adjusting my brake switch till I finally noticed my brake was dragging.
  1. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 08:36 PM
  2. Hi from Australia. Front brake and brake light
    By lozinoz in forum Technical Help
    Last Post: 04-05-2016, 05:21 PM
  3. brake light not working, bulb ok
    By bondfast in forum Technical Help
    Last Post: 08-11-2012, 07:47 AM
  4. Video time... (big-time stuck!)
    By bookm in forum General Discussion
    Last Post: 05-30-2012, 09:54 PM
