2006 very sluggish when cold
Results 1 to 5 of 5
Like Tree7Likes
  • 1 Post By centralwarider
  • 1 Post By elime
  • 2 Post By Blockhead
  • 3 Post By cowboyjeff
Thread: 2006 very sluggish when cold
    Junior Member Gerald's Avatar
    Aug 2014
    saskatchewan
    11
    The 2006 seem to very bad when it is cold but my 1992 seems to have no bog at all and accelerates quickly even when cold.The 2006 seems to get a lot better when I drive it for at least 10 minutes at half choke but still bogs down a lot when trying to speed up. I been driving everyday from +5 to +10 Celsius which is pretty cool. I don't know if I should take the whole carb out and clean it or is there a quick fix by dropping the float bowl.
    Senior Member centralwarider's Avatar
    Mar 2015
    Washington State
    172
    Add a can of seafoam over two tanks of fuel and see if that helps first.
    cowboyjeff likes this.
    2007 TW200, Cycleracks, Jimbo shield, Tinman Tim racks and tool tube mount, Shinko 244 in 5.10, Protaper ATV mid handlebars, Tusk D-flex hand guards, e-bay steel pegs
    6,957
    Maybe open idle mixture screw 1/2 to 1 turn?
    Member Blockhead's Avatar
    Dec 2016
    Pittsburgh, Pa.
    69
    The first two responses are good advice...then you're probably headed for a carburetor rebuild if still having problems. These bikes are easy to work on, plus there's lots of help available from the good folks on this forum if you need it.
    cowboyjeff and centralwarider like this.
    2008 TW200
    2008 YZ250
    2013 Honda CB1100
    2015 Toyota Tacoma
    2016 Mazda CX-3
    2006 Hyundai Sonata
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    I had my 91 Tw acting just like yours when it was cold, It turned out to be the Pilot Jet was party clogged. It took me 3 times dissembling the Carburetor and cleaning it before I finally decided that what looked like a spider web when I looked thru the Jet was not susposd to be there. I pushed thru it with a small wire and the bike was just like new again.
  1. Cold!!!!!!!!!!!
    By scotti158 in forum Off-Topic
    Last Post: 02-16-2016, 09:26 AM
  2. Are all TW's cold blooded?
    By JeffO in forum Technical Help
    Last Post: 11-18-2013, 03:44 PM
  3. A cold ride
    By kj7687 in forum General Discussion
    Last Post: 01-18-2013, 02:59 PM
  4. Cold blooded
    By lakesideboo in forum Technical Help
    Last Post: 05-26-2012, 12:48 PM
  5. Cold starting
    By Boarder255 in forum Technical Help
    Last Post: 11-15-2011, 11:04 AM
