2003 carb. settings?
Results 1 to 3 of 3
    Junior Member 123elementm's Avatar
    Aug 2010
    26
    Just got a 2003 TW that now has 600 miles on it. I want to do the larger main jet and needle shim thing but not sure where to start. 130 132.5 main jet ? .030 shim? What else should I do to check over the bike? Do the valves normally have to be adjusted at 600 Miles? What is a good source for jets?
    Aug 2010
    26
    I live and ride at around 700' elevation, eastern PA.
    No two engines are exactly the same. Your stock main jet is #125. Yamaha has #128 and #132 available. When I have access to real gasoline Tdub runs best with #128 and 2 washers under the needle. When only gasohol is available, Tdub runs best with #132 and 1 washer under the needle. In both cases the pilot screw is adjusted to eliminate off-idle throttle lag when the throttle is opened quickly and surge at steady cruise at 35mph. This can change by 3/8 turn depending on weather conditions. 400ft altitude.
  1. Exhaust mount torque settings
    By devilnutzUSMC in forum Technical Help
    Last Post: 12-19-2012, 03:12 PM
  2. Why doesn't it let me see my settings??
    By Gorilla in forum General Discussion
    Last Post: 07-30-2012, 09:12 PM
  3. Tuning 2003 carb
    By nick2ny in forum Technical Help
    Last Post: 10-27-2011, 02:11 PM
  4. 2003 TW for Sale $750 obo
    By MrClean in forum TW200 Classifieds
    Last Post: 10-15-2011, 06:37 AM
  5. PM Settings
    By RockyTFS in forum General Discussion
    Last Post: 03-30-2011, 12:24 PM
tw200 best carb settings
