How to swap forks from a donor bike
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By TW-Brian
Thread: How to swap forks from a donor bike
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    927
    As many of you know, I recently reached out and touched a tree at high velocity. Frankenstein's front forks just haven't been the same since. Luckily, Charlotte has a set to spare, so will be donating to Frank until I can buy new ones. So before I begin, I have a couple of questions for you guys who have been there, done that:
    • What's the best way to do this? I've watched a ton of videos and think I know what to do. But is it possible to take the shocks off with the wheel still on? Or is it better to just pull everything apart, then slide it all back together again piece by piece?
    • What do you do when the forks don't want to drop? Can I use WD-40 or PB Blast to get them loose? Should I tap the top with a rubber mallet, or will that hurt the cap head?
    • Also, what do you guys use as a center stand/perch for your second bikes when working like this (swapping from donor bikes)? I have a jack under Frank, but will have to come up with something different for Charlotte since I don't have 2 stands.
    As usual, guys, thanks for the advice. I usually like reinventing wheels, but in this case, I'm on a time crunch and hope you don't mind sharing experience and pointers.
    My 2-Wheel Babies: 2017 Versys X 300 - 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2014 Honda Ruckus
    Pleasanton, CA
    5,747
    Yes, you can remove the forks and wheel together as a unit but this will make it significantly harder to do, especially single-handedly. This way would require that you raise the front end quite a bit higher than if you removed the wheel first. Some people raise the front end by suspending it from an overhead beam. If you only have one lift, you might want to "borrow" a milk crate from your local supermarket. A metal one would be best, but plastic will work also. You may need a few spare boards to raise the front wheel enough to remove the wheel.
    Assuming that you are satisfied with the way that the donor bike rides, here is what I would suggest to maintain that alignment when the forks are transplanted onto the recipient bike. Take a Sharpie and make a mark on the fork caps that matches the pinch bolt slot on the upper triple clamp. This way you can line up the legs in the same orientation as they came off. Once the upper and lower pinch bolts are loosened, grab the upper fork legs and see if they can be twisted down through the triple clamps. If they will not rotate freely by hand, take a large flat bladed screwdriver and insert it in the pinch bolt slots, and carefully pry the slots open just a very small amount while twisting the upper fork legs. Once they are freed up, you should be able rotate them down through the triple clamps.
    For re-installation, just reverse the above procedure.
    LuvNot and Fred like this.
    May 2015
    Hampton, VA
    927
    Thanks! This will be my first order of business right after work tomorrow.
  1. Need a TDub Donor Bike To Build a Brat Bike
    By BkCntryCrwlr in forum TW200 Classifieds
    Last Post: 01-19-2015, 07:09 PM
  2. Picked up a donor Xt 350
    By Bucknutz in forum Performance and Customization
    Last Post: 10-22-2013, 06:38 AM
  3. Replies: 5
    Last Post: 05-03-2012, 11:23 AM
  4. Crankcase swap
    By Richb in forum Performance and Customization
    Last Post: 01-05-2011, 10:27 AM
  5. Engine Swap
    By Jackk-92 in forum Performance and Customization
    Last Post: 12-01-2010, 11:04 AM
