Accidentally left petcock open, fuel on floor...is my float stuck?
Results 1 to 10 of 18
Like Tree38Likes
Thread: Accidentally left petcock open, fuel on floor...is my float stuck?
    Junior Member erleichda's Avatar
    Jan 2017
    9
    As per title, is this a symptom of a stuck float? I can crack the bowl and see if it moves freely, but do I have to or is this normal if petcock is not closed? Fuel was dripping out air filter.
    Ken and Cornelis like this.
    Senior Member drstimpy's Avatar
    Oct 2013
    Rochester, MA
    238
    Float needle seal may need refreshing.
    Ken and Moabman like this.
    Some must watch while others must sleep.
    2013 TW 200
    2014 NC700x
    2016 k1600gt
    2016 TW 200
    May 2013
    Groton, NY
    2,663
    Probably time for a new needle and seat and a good carb cleaning.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Jun 2016
    New Rochelle, New York
    1,731
    If you have a kick starter, without the ignition on try and slowly turn the motor. No kickstarter... put it in third and turn the engine. You can do both of these with the spark plug out if you feel a lot of pressure and fuel got into your engine. A good way to avoid Hydrolock.
    Ken and Mifrank67 like this.
    Hailey, ID
    3,307
    Quote Originally Posted by erleichda View Post
    As per title, is this a symptom of a stuck float? .........
    Yes, precisely. Or a leaking float needle seat. If gas was dripping out the airbox, it was also likely dripping into the cylinder, so you will need to check for gas smell at the oil filler neck...probably you should assume the oil is contaminated with a substantial amount of gas...not good for bearings.....AT ALL!
    If all the above is normal, the petcock can be left on for long periods, AS LONG AS THE BIKE IS NOT TRAILERED!
    Ken, Cornelis and jtstdub like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,900
    Check the oil to make sure it doesn't have gas in it. If it does change it out. The engine could explode if a spark were to ignite trapped vapors in the crankcase. Sometimes just a small bit of trash can hold a needle open and cause it to leak. I always shut the petcock off because this can possibly happen at any time. As others stated your seat and needle could be worn.
    6,954
    I had this problem and it was an o-ring. See red arrow -- I replaced it and all was well.
    Or it could be the needle.........
    Ken, jbfla, Cornelis and 2 others like this.
    Senior Member Rockit's Avatar
    Jun 2016
    Sacramento
    158
    I had this same issue happen when I trailered my TW from Sacramento to San Diego. Before I left I made sure the petcock valve was set to off and I ran all the fuel out of the carburator. When I got to San Diego I opened the petcock valve and fuel started overflowing from the carburator. I read on line that the float might be stuck so I hit the carb bowl with a ratchet handle a couple of times. I then turned the petcock valve to the on position and everything worked fine. It's an easy way to attempt a repair. Give it a shot.
    elime and Ken like this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Yes, your bike is incontinent.
    1911garand, jtstdub, Ken and 1 others like this.
    Phelonius
    Junior Member olderthandirt's Avatar
    May 2017
    7
    Rocky - your comment on trailering may help me - I am a new TW200 owner and noticed today while trailering that fuel was dripping out of the float bowl drain hose. I stopped to check the tie down and noticed a drip that stopped soon after I pulled over. The drain screw was tight and the fuel petcock was in the on position. Appears to only drip when trailering - not when stopped or riding. Bike runs good before and after. What gives?
    Ken likes this.
  1. Left petcock open for a couple weeks, bike won't fire up
    By Armitage in forum Technical Help
    Last Post: 03-12-2016, 07:03 PM
  2. From stuck float valve to no clutch....related?
    By rodknu in forum Technical Help
    Last Post: 11-09-2014, 08:53 PM
  3. Stuck needle float valve Seat
    By Bucknutz in forum Technical Help
    Last Post: 04-06-2013, 09:55 PM
  4. Who turns off the fuel petcock after each ride?
    Last Post: 11-17-2012, 01:27 PM
  5. Fuel petcock question
    By Boarder255 in forum Technical Help
    Last Post: 06-19-2011, 03:22 PM
fuel petcock on gas on floor
tw200 stuck float needle
