What is this carb part?
Results 1 to 8 of 8
Like Tree11Likes
  • 1 Post By thidwick
  • 4 Post By Skin Walker
  • 2 Post By Skin Walker
  • 1 Post By phelonius
  • 2 Post By thidwick
Thread: What is this carb part?
    Member thidwick's Avatar
    Nov 2016
    Raleigh, NC
    47
    Question What is this carb part?
    I have a 2013 TW200. I took the carb apart to clean it and put it back together. Being that this was my first time working on a carb, I bet you know how it went when I started up the bike.
    I took it apart again and started over. When I referred back to the diagram, I noticed I was missing a little part that is drawn in the technical manual diagram. The part wasn't listed with a name or in any of the subsequent instructions, but I found it on Partzilla listed as "main nozzle" (5LB-14341-00-00). The confusing thing is that the manual refers to part 5LB-14341-10-00 (Partzilla) as the main nozzle. I'd be much obliged if someone would please clear up the ambiguity surrounding this phantom piece.
    Ken likes this.
    Senior Member Skin Walker's Avatar
    Nov 2015
    346
    As taken from another post on the forum....
    #13 from the parts diagram appears to be the main jet holder but i think you would have noticed that when putting it back together - however, I think what you are referring to is maybe #12 which is the main nozzle.
    Go through this dude's pics and check them out...
    http://s42.photobucket.com/user/masc...plies.jpg.html
    Heck, If you'd send me that carb I'd clean & rebuild it and make it spotless for free!!! ( I may be spending quite a bit of time in Durham NC here soon, with my hydraulic lift, bikes, parts and bike tools )
    Ken, thidwick, jtstdub and 1 others like this.
    - SW
    2006 TW
    1998 TW
    1996 TW
    1993 TW
    1985 BW200
    1987 B200E
    1979 Honda Z50
    ..and 1 Chihuahua
    Nov 2016
    Raleigh, NC
    47
    Thanks much!
    It's slightly frustrating that the service manual doesn't reference it (that I've seen, anyway).
    Ken likes this.
    Nov 2015
    346
    No sweat! I love getting my hands on a junked, gummed abused carb and making it 100% - an easy thing to rebuild and service.
    YOu got this man! heheh
    Ken and thidwick like this.
    - SW
    2006 TW
    1998 TW
    1996 TW
    1993 TW
    1985 BW200
    1987 B200E
    1979 Honda Z50
    ..and 1 Chihuahua
    Nov 2010
    Frostbite Falls Ill
    2,719
    It's a framis. It is for velocitating the fuel vapors.
    jtstdub likes this.
    Phelonius
    Dec 2015
    San Diego
    1,857
    The main nozzle seems to fall out when you take it apart. You are not the first to miss place it.
    Nov 2016
    Raleigh, NC
    47
    It looked pretty clean already when I opened it up (maybe from the sea foam), but I still soaked it in kerosene. I also replaced the leaky gasket and adjusted the float to be within spec. Fortunately, I had already ordered a replacement for that part and a couple others that showed some wear, so I was able to get it back together last night. She's running beautifully now!
    Tweaker and socalnative like this.
    Nov 2016
    Raleigh, NC
    47
    Quote Originally Posted by Skin Walker View Post
    Thanks for the offer! Hit me up when you're around in Durham and we'll go riding.
  1. loking for carb part 01+
    By supachip1 in forum Technical Help
    Last Post: 02-28-2017, 02:23 PM
  2. Is carb part in the correct way round?!
    By SandyShore in forum Technical Help
    Last Post: 06-19-2016, 06:03 AM
  3. TW carb jet part#s
    By Leisure Time Larry in forum Technical Write-Ups
    Last Post: 05-19-2014, 09:22 PM
  4. 1987 Carb part identification
    By BBMS in forum Technical Help
    Last Post: 08-05-2011, 04:40 AM
  5. Part number for Carb float bowl drain screw?
    By RadV in forum Technical Help
    Last Post: 09-16-2010, 06:16 PM
