Intermittent issue when shifting from 2nd to 3rd...what could it be?
Results 1 to 10 of 12
Like Tree24Likes
Thread: Intermittent issue when shifting from 2nd to 3rd...what could it be?
    Member Lynlee's Avatar
    Mar 2017
    San Diego
    40
    So I notice when I got my TW (a new 2016), I found some issues when upshifting. I would pull the clutch in and shift up, let the clutch out and the bike would still be in the same gear. For a time I though I was not hitting the the shifter hard enough....but then I started paying attention and it only happens from 2nd to 3rd. This doesn't happen all the time, maybe 1:15 times and sometimes it take a few tries to get it into 3rd. What on earth could this be since it is only from 2nd to 3rd? A TW riding friend is going to help me with my first service, but I am wondering if I should consider taking it to dealer if there is something else going on. It is under warranty.
    Any ideas?
    Thetrainer and Ken like this.
    Dec 2015
    San Diego
    1,864
    That is weird. I don't know what it could be. Not that familar with working on the transmission. What if your clutch is still a little sticky?and not releasing all the time? WAGs maybe it will clear up over time. I know you can shift with out the clutch which makes this weird. Any way you might want to tell your dealer about it now and document your problem.
    socalnative, Ken and Lynlee like this.
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    338
    make sure your shifter pedal is not contacting the engine....
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Colorado
    1,166
    Sounds like bent shift fork probably. Could also be shift shaft, gear detent, shift drum, worn dog gears. You'd have to take it apart and have a look to be sure.
    Ken likes this.
    Member Blockhead's Avatar
    Dec 2016
    Pittsburgh, Pa.
    69
    Have you changed/check your oil lately?
    2008 TW200
    2008 YZ250
    2013 Honda CB1100
    2015 Toyota Tacoma
    2016 Mazda CX-3
    2006 Hyundai Sonata
    May 2013
    Groton, NY
    2,663
    Quote Originally Posted by Blockhead View Post
    I was thinking this also. Fresh Mobil 4T may help.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Nov 2010
    Frostbite Falls Ill
    2,719
    Bent shifter foot.
    Ken and Fred like this.
    Phelonius
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    When mine starts shifting funny that's how I know it's time to change the oil.
    Ken, Lynlee and scotti158 like this.
    Nov 2016
    So. California, inland empire
    309
    How is down shifting from 3rd to 2nd?
    Ken likes this.
    Apr 2014
    982
    Lynlee; as it is a new bike (month or two old); other than checking to make sure nothing visible on the exterior is the problem (like shifter contacting the case as stated) -- I would take it to the dealer you bought it from (at least to document the problem like Tweaker mentioned) BEFORE you and your friend do the first service. Just so the dealer cannot say that anything that you do could have caused a problem.
    Brand new bike - their problem under warranty. And documented if they can't find anything and it is a further problem down the road.
    Ken, socalnative, Tweaker and 1 others like this.
  1. Intermittent Fuel Overflow
    By tee-dub in forum Technical Help
    Last Post: 09-20-2016, 05:36 PM
  2. Intermittent power loss
    By drsquat in forum Technical Help
    Last Post: 07-07-2016, 06:01 PM
  3. Going Moab May 2nd & 3rd
    By Bodi in forum Trails, Off-road, and Adventure Riding
    Last Post: 04-14-2015, 08:48 PM
  4. Intermittent tick at idle after adjusting the valves
    By btrnrsntfl in forum Technical Help
    Last Post: 06-17-2014, 03:55 PM
  5. 3rd T-dub in 4 months
    By sherm in forum General Discussion
    Last Post: 01-17-2011, 05:58 AM
