Leaky gas cap lock cylinder
Results 1 to 10 of 11
Like Tree10Likes
Thread: Leaky gas cap lock cylinder
    18,561
    My California CARB compliant gas cap insists on venting through the lock cylinder rather than through the charcoal canister. As a legislatively neutered politically correct thoroughly intimidated west coast liberal I am concerned that these vapors will possibly end life as we know it, melt the glaciers and at least lead to a second republican administration. What can I do?
    Seriously the smelly staining leaks are annoying and occur not just when I fill the tank to, or above the “slosh line” near top of tank. Perhaps I can remove lock cylinder and sandwich a rubbery membrane between cylinder and gas cap main body to create a seal? I would rather not use a permanent sealant. My need to use the key has been dis-abled so this key slot access is not an issue.
    Any ideas?
    Senior Member centralwarider's Avatar
    Mar 2015
    Washington State
    172
    No ideas on the fix, but mine is doing the exact same thing and is not handicapped with any CA emissions compliant components
    2007 TW200, Cycleracks, Jimbo shield, Tinman Tim racks and tool tube mount, Shinko 244 in 5.10, Protaper ATV mid handlebars, Tusk D-flex hand guards, e-bay steel pegs
    18,561
    Misc. observation: Overfilling a California tank seemingly can lead to saturating the charcoal canister with liquid gasoline which then creates vent issues leading to seemingly inexplicable engine stalling. Engine would die under sustained wide open throttle only to restart after 30 seconds or so once an alternate vapor leak restores atmospheric pressure to the tank ( i.e.through my key-hole). Problem disappeared once tank vent was disconnected from charcoal vapor recovery canister.
    jtstdub and Dryden-Tdub like this.
    6,955
    I used a piece of Gorilla Duct Tape. Its not pretty but it is cheap and will need to be replaced periodically but that easy to do.
    If you don't have Gorilla Duct Tape.........what can I say? Shame ! Shame !
    centralwarider and jtstdub like this.
    6,955
    I forgot to add that this is a Calif. bike sans smog stuff. The vent exit on the bottom of the tank has been blocked off with a bolt and o-ring and the cap even with the duct tape still vents the tank. I dread the day Calif. starts doing smog checks on motorcycles.
    You might try getting a non Calif. gas cap and let the tank breathe.
    18,561
    Does the Gorilla tape hold up? I may go slap some on for today’s ride as a test and deal with any gummy residue later.
    At one time I had Gerry’s Mr.Gizmo watch Velcroed to the cap so I could see time at a glance, yet pull timepiece off and put in my pocket for a off-bike hike. Darn gas vapors dissolved the velcro adhesive and watch fell off somewhere in Utah.
    6,955
    Eventually it comes off and if you tank has positive pressure it might come off sooner. But yes, it holds on my cap.
    18,561
    Thank you for once again another one of your helpful tips Tony.
    littletommy likes this.
    6,955
    Lets wait and see how it works out before you thank me.
    18,561
    Good point Tony. Sure enough the tape stopped the leak but caused the bike to stall during sustained wide open throttle operation.
    Ah ha, a venting issue had revealed itself! Yep, a quick inspection showed that mud thrown up from front tire had clogged the factory vent tube opening.
    Funny how susceptible these constant velocity carbs are to venting deficiencies in both the carb and tank vents.
    So I guess I still must thank elime for the tape trick revealed the need to check the normal vent route.
    Thanks Tony, I benefited from the unanticipated consequences of your simple solution.
    admiral, littletommy and elime like this.
  1. Replies: 0
    Last Post: 09-03-2015, 10:05 PM
  2. Replies: 0
    Last Post: 08-04-2013, 10:23 AM
  3. HOW TO: RE-KEY GAS CAP & HELMET LOCK
    By blowout in forum Technical Help
    Last Post: 08-01-2013, 09:00 PM
  4. Sell or trade Ignition, Gas Cap, Helmet lock and key
    By TeeDubs in forum TW200 Classifieds
    Last Post: 03-22-2012, 07:16 PM
  5. WTB - TW200 matching switches - Ignition, gas cap, lock
    By Vrroom in forum TW200 Classifieds
    Last Post: 12-28-2010, 07:18 AM
