Bikemaster TruGel battery
Results 1 to 4 of 4
Like Tree3Likes
  • 3 Post By RockyTFS
Thread: Bikemaster TruGel battery
    Member Joecabinetti's Avatar
    Dec 2016
    51
    Has anyone tried one of these battery's? They are on E-bay for a little over fifty bucks. I like the idea of no battery acid sloshing around so I figure for an extra ten bucks or so it might be worth it. Or can anyone suggest an alternative? I mostly ride back roads at a slow pace so an acid battery would be ok if it was more reliable.
    Hailey, ID
    3,311
    Have a look at this: https://tw200forum.com/forum/performa...l-storage.html
    The Bikemaster True Gel has too many negative reviews on Moto Superstore for me, I would get an AGM instead.
    Yamaha 2007 TW 200 Trailway TW200W1C Motorcycle Battery Sealed Maintenance-Free oem fit
    There are cheaper AGM's, but I probably wouldn't buy one off fleabay. This one looks good. My AGM has lasted five years. You MUST first trickle charge it overnight if you want it to last!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Member moresnow's Avatar
    Oct 2012
    Iowa
    75
    I've used 2 cheapy ebay batts in the last several years. One on a 250 and one on my 650. Both worked just fine. Guess I've been lucky! I'd have to go look at the brand name?
    Dec 2016
    51
    Thanks for the advice. I just ordered a Yuasa Yumicron. It was $41 on e-bay.
  1. Battery life sucks...what battery are you using?
    By rastaman in forum Technical Help
    Last Post: 07-21-2019, 11:06 AM
  2. New battery and tw will not maintain a charged battery
    By Mr.wiggle in forum Technical Help
    Last Post: 06-27-2016, 08:06 AM
  3. Battery Tender (battery) Headache
    By Dmd3058 in forum Technical Help
    Last Post: 04-03-2016, 04:10 PM
  4. TruGel battery
    By Wambat in forum Technical Help
    Last Post: 12-19-2015, 02:39 PM
  5. Replies: 3
    Last Post: 02-05-2015, 11:55 PM
