Plastic Repair
Results 1 to 10 of 13
Like Tree7Likes
Thread: Plastic Repair
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    Plastic Repair
    I have been trying to repair a front signal light arm with no luck, I tried Super Glue, I tried Fiber Glass, no luck, so I even tried melting the plastic with my sodering iron, It will not even stick to its self. Have any of you found anything that sticks to this kind of plastic?
    Nov 2016
    So. California, inland empire
    309
    Isn't the flexible arm area a kind of rubber?
    Nov 2013
    West Jordan, Utah
    207
    I think it is for the first couple inches and then it turns to a hard material before the lenses, mine broke off right at the starting of the lenses.
    Nov 2013
    West Jordan, Utah
    207
    I just found a replacement on eBay for $32.00 including shipping, I ordered it. I steal would like to repair the broken on if possible.
    Jun 2014
    Bel Air Maryland
    4,169
    I hot glued one of mine
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    18,570
    Funny thing, just spent the weekend camp-n-ridin’ with a chemist and the subject of difficulty in building high molecular weight bonds in such materials came up. Simple laymen’s answer is you won’t rely get reliable penetration bonds with common adhesives but with scoring keyways and roughness on the surfaces to be joined one can at least improve a mechanical bond. By increasing the surface area for the adhesive and the scoring creates keyways for the adhesive to flow into one can create a mechanical “lock". Longer curing times for glues build longer chains with higher molecular weights and thus improve strength.
    Unfortunately after a full day’s riding and several adult beverages sitting around the campfire I cannot recall the chemist’s name for the class of adhesives with elastomizers that would work best on things like turn signal stalk. Sorry.
    Nov 2013
    West Jordan, Utah
    207
    Thanks Fred, I have really made a mess out of it now trying to weld with a soldering iron. Toppredator I did not think to try a Glue gun, Im going to give it a try and see what happens. Thank you very much.
    TopPredator likes this.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,994
    I just fixed a hole in a buddies kayak he wore in it while dragging it many times. I could stick 3 fingers through the hole. I used fiberglass cloth and west marine epoxy resin and hardener. Kayaks are made from I believe PEF or PEV plastics very similar to a 5 gallon bucket and not much will stick to it very well. I used a wood rasp file to rough up the surface with fairly deep gouges. I wiped the area with acetone before applying the liquid and fiberglass cloth. I did 3 layers of the cloth/resin and let it dry over night to completely hard. SO far so good and the patch it holding quite well. Only time will tell from this point.
    I have a place here that welds this type of plastic but I have never seen it done or the resulting repair. What I suspect is both sides of the crack, just like in welding steel, must be heated and melted together or if using a glue it must have the ability to melt, penetrate or in some way attack both surfaces in order to make a good bond. I am a woodworker and can tell you for sure when I glue 2 pieces of wood together the glue line is often stronger than the wood itself. Never have had that result while messing with plastics and the various epoxies because there is no open pores for the glues to get in and bond to. Almost always plastic will brake again right at the repair seam.
    1987 Yamaha BW350 Big Wheel
    Senior Member centralwarider's Avatar
    Mar 2015
    Washington State
    172
    I would glue it with these bro. Should be plug and play, incandescents, front and rears available, all four for less than $30, and they are short enough not to get crunched when the bike insists on resting alongside your route.
    2007 TW200, Cycleracks, Jimbo shield, Tinman Tim racks and tool tube mount, Shinko 244 in 5.10, Protaper ATV mid handlebars, Tusk D-flex hand guards, e-bay steel pegs
    18,570
    I too have used the West Marine system successfully on rotomolded kayaks; pure white,available in a paste or putty.
    Another example of good product I have used on high impact nylon RC models; creamy color, unique odor as it cures, ductile, vended under a variety of names: 51cR-1vRBhL.jpg
    In addition to the roughening Gary does I also like to run a razor blade across the surfaces to be joined repeatedly at a variety of angles cutting mini-flaps for the adhesive to wrap around and grab in three dimensions.
    There are also UV activated adhesives that rely on a propogation reaction to cure but my experience and success are limited.
  1. Plastic Repair Advice
    By DrTerrible in forum Technical Help
    Last Post: 07-20-2016, 10:42 AM
  2. Exhaust Repair
    By Mattwings in forum General Discussion
    Last Post: 06-10-2016, 08:50 PM
  3. tractor repair
    By plumbstraight in forum Off-Topic
    Last Post: 05-07-2016, 04:17 PM
  4. Exhaust repair (Help)
    By tcepilot in forum Technical Help
    Last Post: 11-10-2014, 09:58 PM
  5. Petcock repair
    By Tirebiter in forum Technical Help
    Last Post: 04-15-2013, 07:23 PM
