air filter debris
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By TopPredator
Thread: air filter debris
    Member Yan's Avatar
    Aug 2013
    72
    air filter debris
    so I went to change the air filter
    found it stuck to the metal screen it sits against (too much oil last time or installed too early before the oil dried up, whatever could've caused it)
    ripped the filter off and a noticeable portion of it left on the screen. started cleaning the screen with a plastic brush, and by the end of it realized that I must've pushed some of the debris past the screen, which means they will most likely go down the pipe. How much damage can it cause? Or it will all just burn off in the cylinder?
    Thanks!
    P.S. Tried to take the plastic part with the screen off but some of the screws retaining it in place are obscured by the frame. Gave up on it.
    Jun 2014
    Bel Air Maryland
    4,169
    It is a PITA to remove the Air Box. I can't imagine it will hurt anything to have a little debris pass through the Carb. How old is your filter? A new filter oiled should not stick to your screen.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    Member Yan's Avatar
    Aug 2013
    72
    Quote Originally Posted by TopPredator View Post
    hard to tell the age of the filter. we have 2 bikes, and 4 filters. one filter is from 2001, the other 3 filters are only a few years old. It could've been the old filter, but no way to tell.
    just to confirm - the air doesn't really go through the carb, right? I mean it's the fuel that passes through the jets and such, air just goes down the intake pipe, correct? So those debris aren't going to clock anything in the carb itself, they will just end up in the combustion chamber, right?
    Thanks!
    Member Yan's Avatar
    Aug 2013
    72
    as far as sticking to screen, I use Notoil, and it's a very very tacky stuff. So I am not surprised it stuck to the screen, I should've given it more time to dry I guess.
    Jun 2014
    Bel Air Maryland
    4,169
    Quote Originally Posted by Yan View Post
    Thanks!
    Correct nothing will get in the jets. Here's pictures of a TW carb where you debris will pass through.
    Closed Throttle
    Half Throttle
    Wide Open Throttle
    elime likes this.
    TW 2006 Ruth
    1994 Harley FXR
    Rick
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    338
    My screen went MIA a long time ago!
    Member Yan's Avatar
    Aug 2013
    72
    Quote Originally Posted by lbxr View Post
    that would definitely solve my problem
    Jan 2015
    Gold Beach Oregon
    338
    My understanding of the screen is that it is a flame arrest (er) for backfires thru the intake....i have removed them from many bikes w/o any issues. YMMV...
  1. Now That's A Dirty Air Filter!
    By Fred in forum General Discussion
    Last Post: 09-25-2016, 11:36 AM
  2. It's all in the air filter!
    By kj7687 in forum Other Bikes
    Last Post: 08-05-2016, 01:15 AM
  3. Air filter Mod
    By jimmytanko in forum Technical Help
    Last Post: 10-03-2012, 06:41 PM
  4. air filter element
    By sea bass in forum Technical Help
    Last Post: 08-25-2011, 01:52 PM
  5. air filter cleaning
    Last Post: 08-15-2011, 10:42 AM
