Bike won't start after I washed it down
Page 1 of 3 123 LastLast
Results 1 to 10 of 30
    Junior Member fujimo's Avatar
    Mar 2012
    Tampa, FL
    15
    I went out today and ran through a retention pond I thought was dry...
    I got stuck and I was pulled out by some good Samaritans.
    I washed the bike down with a pressure washer, and now it won't start.
    I drained the carb, checked the plug... and I guess I should let it dry?
    I feel stupid.
    Any thoughts?
    Aug 2011
    Cayce, SC
    3,109
    Did you get water or mud in your exhaust or air filter passage under the seat? You may also want to check your carbs vent hose. Other than that, I dont know.
    Looks like a dinosaur stuck in a tar pit.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Mar 2012
    Tampa, FL
    15
    Did you get water in your exhaust or air filter passage under the seat? You may also want to check your carbs vent hose.
    I think I got water in the exhaust.
    I don't know about the vent hose. I don't think I got water up in there. Do I take the hose off to check?
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Geez, water in the exhaust? Not sure of which step to take next. My only advice is DONT try and start it! Leave it and wait for the other guys to respond. Water doesnt compress so if you crank it over hard enough you'll kill it dead.
    Tenaciously Deviant Unwittingly Brilliant
    Aug 2011
    Cayce, SC
    3,109
    Quote Originally Posted by fujimo View Post
    If it's not clogged youre fine. You can take it off to check. If you know you got water in the exhaust, take it off, dump it out and let it dry. Drain the bowl for good measure and try it again after it has fully dried!
    Tennessee
    1,279
    First, does it turn over with the e-start and will it kick through?
    Mar 2012
    Boonville, No.-Calif.
    1,355
    Remove the spark plug before kicking/cranking the engine. This should clear any water that may have made its way to the cylender either by entry through the intake or exahust. Spray a little WD 40 down the spark plug hole & with the spark plug out, turn the engine over, preferably with the electric starter as it will turn the engine much quicker & help to clear water from the cylender. Also make sure your air filter is not saturated with water / oil, as this can choke off combustion. Better change your oil too, when you get the prob solved, as you may have water in it, water can slip past the rings if it is present in the cylender, as well as entering thru vents, etc. Just a good idea. Check for spark while you have your plug out. I've done the same thing on my old XL250 at a bark dump years ago, burried it up to the bars!! Ahhhh! m.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Won't start, how??
    Won't turn over at all, or turns over but won't run?
    With all that mud, then cleaning, you might have pulled a wire loose on a safety relay.
    Also, potato in the tail pipe... is the exhaust clogged? Is the air box clogged?
    Stephen S.
    '07 TW200:
    Mar 2012
    Tampa, FL
    15
    Engine turns over. No ignition.
    As soon as I read the posts, I stopped trying to start it.
    I am pulling the exhaust off.
    I will replace the plug, cause it's dirty...
    I will see about changing the oil.
    I am missing a drain tube for the carb.
    I think there was some bits of dirt in the carb bowl when I drained it.
    Dangit. I just had the carb done at the dealership. That was pricey. I bet the jet has mud in it.
    Mud everywhere...
    6,932
    Don't forget to clean and oil the chain.
  1. Replies: 50
    Last Post: 01-19-2015, 07:33 PM
  2. Bike won't start in the mornings!
    Last Post: 11-27-2012, 07:56 AM
  3. bike locked up...where to start?
    By operose in forum Technical Help
    Last Post: 03-19-2012, 01:37 PM
  4. my bike wont start
    Last Post: 07-01-2011, 12:02 AM
  5. My bike won't start
    By jasonck08 in forum Technical Help
    Last Post: 11-15-2010, 01:57 PM
after washing bike it will not start
bike not starting after washing
dirt bike wont start after washing
i washed my motorcycle and now it wont start
motorcycle not start after wash
old bike starts missing after wash
washed my bike now it wont start
washed my dirt bike now it wont start
washed my ktm 50 now wont start
what to do when motorbike not starting after wash
why motorcyle not star aftre wahsing
why my bike does not start after washing
