Front sprocket case
Results 1 to 10 of 11
Like Tree37Likes
Thread: Front sprocket case
    Junior Member Dwhiting24's Avatar
    Jun 2017
    12
    Front sprocket case
    Hey guys just wondering if I take that casing off that holds the front sprocket if the left side full of oil? Or what's under there?
    Ken likes this.
    Feb 2013
    Missoula, MT
    908
    Under mine I found rainbows, bunny rabbits, and candy. You will probably find a small amount of oil and the stator windings. However, your joy could soon lead to sorrow if you are not VERY careful when you re-install the cover and pinch those two f'ing wires that fit(?) in a tight grove in the case and cover.
    This one thing took me over an hour to get fit correctly, the first time I did it. And, that was after I ate all the candy.
    #2? Buy a new gasket. It's price will teach you not goof around in here unless it is ABSOLUTELY necessary.
    Have fun! That's what TWs are for and you never know what you will find inside the engine.
    Ken, Purple and TopPredator like this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,902
    I think you are correct that the front sprocket shaft seats into the cover on the left side. There is an oil seal. There is a small amount which dribbles out if I recall correctly. The oil doesn't poor out when disassembling.
    Mel and TopPredator like this.
    Senior Member Skin Walker's Avatar
    Nov 2015
    346
    That's odd.
    I found a bag of sunshine, giggles and rainbows in mine. I called the cops and they confiscated it.. Asked me if I had seen any gypsies or carnival workers..
    Hehehe...
    Dryden-Tdub, Ken and TopPredator like this.
    - SW
    2006 TW
    1998 TW
    1996 TW
    1993 TW
    1985 BW200
    1987 B200E
    1979 Honda Z50
    ..and 1 Chihuahua
    Pleasanton, CA
    5,686
    There is oil contained by the left side cover. If you don't want to drain your oil, or lose a portion of it, you can just lean your bike partially over on its right side. Take care to ensure that you don't lean it over too far, or you may leak gas from your tank or electrolyte from your battery.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,998
    What TWBrian said is the right answer. All I ever found when removing the left side case cover was a PITA (Pain in the A$$). To clarify that, You will almost always need a new case gasket and you must clean all the old gasket off from both sides before replacing the new one. You should clean all the crud from the sprocket compartment and be very careful getting the wires in the correct slot that go up under the seat. There are seals on the shift shaft, main shaft and on the neutral switch that should be checked and I usually just replace them while I am in there. There is a bearing and seal for the output sprocket shaft inside the case cover I also replace when ever I install a new front sprocket. Because of all of this I always recommend you do the job right, do it all just once and leave the front sprocket the stock 14 tooth and make gearing changes from the rear sprocket if you want to change gearing. I top it off by adding a very good quality O or X ring chain that will last way longer, reduce the sprocket wear and keep you from having to adjust the chain every few hundred miles. When you do it right you should be good for at least 10,000 miles with very little else to do. I also always remove the gas tank and the seat and battery and just lay the bike on the side when I do this work so I get no leaks and can work at my leisure from a good position. Before you remove the first side case cover screw you lay the new gasket on a piece of cardboard and trace it with a pencil and poke holes where each screw goes. As you remove the screws poke them into the cardboard so you know which screw goes back into what hole, they are all different lengths.
    I will also recommend you have an Impact driver and the correct size #3 JIS or #3 Cross Point bit to fit the case screws so you don't round them off by using a regular #3 Phillips head bit.
    1987 Yamaha BW350 Big Wheel
    6,958
    Also clean the outside of the case so dirt doesn't get into the engine when you remove the cover.
    Have a new gasket handy in case you need it but reusing the old gasket is OK if it separates in one piece i.e. it doesn't rip.
    I like to buy a complete gasket set if I can find one for about $35 instead of just the side cover gasket. That way down the road, when o-rings and other gaskets start to leak I have them already. In the long run it is much cheaper.
    Jun 2014
    Bel Air Maryland
    4,169
    I found a bag of dope in my California model.
    Ken, admiral, littletommy and 1 others like this.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
    6,958
    Quote Originally Posted by TopPredator View Post
    That explains things.........
    littletommy likes this.
    Jun 2017
    12
    Okay thanks for your input that helps, its leaking from that gasket already from previous owner so that's why I wanted to know what I'm going to get myself Into when I replace it so all the info helps a lot!
  1. Combo pack - new air filter, front sprock & LHS case gasket
    By turborob in forum TW200 Classifieds
    Last Post: 11-07-2014, 06:46 AM
  2. New Front Sprocket
    By RTG in forum TW200 Classifieds
    Last Post: 06-12-2014, 06:17 AM
  3. I need a front fork cap....mine has a bad case of stripped.....
    By mmmsssggg21 in forum TW200 Classifieds
    Last Post: 02-12-2014, 04:36 AM
  4. front sprocket
    By JMFLH in forum Technical Help
    Last Post: 10-24-2011, 01:24 PM
  5. Modify Case for access to front sprocket?
    By darnold87 in forum Technical Help
    Last Post: 01-07-2011, 01:04 AM
