Locked up front brake
Results 1 to 7 of 7
Like Tree14Likes
  • 1 Post By Waymore
  • 5 Post By Fred
  • 2 Post By Purple
  • 1 Post By Waymore
  • 1 Post By Ken
  • 1 Post By Ken
  • 3 Post By Fred
Thread: Locked up front brake
    Member Waymore's Avatar
    Apr 2017
    Payson, Utah
    72
    My 92's front brake has started locking up every time I pull the lever. To my untrained eye the cable appears to be fine, but I'm pretty new to owning motorcycles or really anything with a small engine. I can push the lever back out and it releases it but it won't release on its own. Would that be a cable issue or something else?
    Ken likes this.
    1992 TW200 6300 miles. Supposed engine rebuilt by previous owner
    18,853
    The perch holding the brake lever can be too tight pinching the brake lever, or the cable could need lube, or the shoes could be so worn that the actuating cam inside the drum could be locking the shoes deployed out, etc.
    Best bet might be to test and lube/adjust the elements while searching for the source of the locked up brakes. For example pull the actuating arm off the drum and see if there is any binding while pulling the brake lever, etc.
    Bobo413, littletommy, Ken and 2 others like this.
    Mar 2015
    Ynys Môn
    4,594
    DO NOT pull the actuating arm off the drum – you’ll never get it on in the correct position again
    Simply slacken off and disconnect the cable at the front wheel, it’s a lot easier
    Then work the “actuating arm” to engage the brake, and see if it releases – you’ll need to apply a good amount of pressure, but if all’s well, it should release smoothly
    If it does release – start looking at the cable itself – simplest thing to do if it’s stiff is to replace it, or (a) it’ll only happen again, and (b) you’ll only end up replacing it in the end
    (Sorry Fred, but that's been my experience anyway) ……
    Ken and Waymore like this.
    - Hidden Content
    Apr 2017
    Payson, Utah
    72
    Actually I didn't even think of it but I replaced the throttle tube and didn't ride the bike after for a few days just started it to test. I probably titghtened the perch up too much and didn't realize it! If that doesn't work I now know where to start from there. Thanks guys!
    littletommy likes this.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,934
    Are you sure there is no oil or contaminates on your brake shoes? That will cause them to grab. I put antiseize on the actuating cams. My brakes didn't fully lock up but they would be grabby when cold or when I hadn't ridden it for a bit. I do have to flick my lever back out after braking.
    Waymore likes this.
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,934
    I haven't been inside the brake area in a while but you may want to check any springs inside the drum. Maybe they are too stretched out and not pulling it back after the brake has been applied.
    Waymore likes this.
    18,853
    Thanks Purple, I’m a disc brake kind of guy so defer drum disassembly tips to you Druids and other old fashioned types who would enjoy Stonehenge on the summer solstice. The intent, however accomplished, is to separate the elements a bit so as to isolate the problem.
    Mel, Purple and Waymore like this.
  1. Big wheel front conversion with disc brake - 32H front hub options?
    By mr200sx in forum Performance and Customization
    Last Post: 04-28-2017, 09:41 PM
  2. Front brake locked up.
    By Dead Drift in forum Technical Help
    Last Post: 06-06-2016, 08:28 AM
  3. Hi from Australia. Front brake and brake light
    By lozinoz in forum Technical Help
    Last Post: 04-05-2016, 05:21 PM
  4. front brake or rear brake for hill starts
    By mrx916123 in forum General Discussion
    Last Post: 03-27-2016, 06:29 AM
  5. Front brake '99 - '01
    By dutchbat in forum Technical Help
    Last Post: 05-25-2013, 05:46 AM
