Tap and die, thread cutting, thread chasing question.
Results 1 to 5 of 5
Like Tree8Likes
  • 1 Post By jgaff
  • 1 Post By phelonius
  • 4 Post By elime
  • 1 Post By jgaff
  • 1 Post By jb882
Thread: Tap and die, thread cutting, thread chasing question.
    Senior Member jgaff's Avatar
    Massachusetts
    124
    Is there any particular reason to NOT rethread a valve adjuster screw hole and screw if the screw turns rough? Any issue with either rethreading with a bottom tap or a thread chaser?
    Thx
    JG
    Ken likes this.
    2010, Happy Trails rack & side boxes, Ricochet skid plate, Clarke tank, Stearns seat cover, rejetted, Shinko 244 front tire.
    New England Denizens of Doom # TW200
    Try to understand things. Be nice to each other.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Just pull the threaded piece out and use it to match to your die before running it through the piece.
    Oh, and check to make certain that the male threads are not damaged either.
    It sounds as if someone has tightened the lock nut too tightly on your machine.
    Ken likes this.
    Phelonius
    6,957
    Quote Originally Posted by jgaff View Post
    No problem at all. I have done it with good results.
    Just make sure the threads on the bolt match the threads on the tap perfectly and gently turn the tap making sure it isn't cross threaded.
    Valve cover bolt:
    Go to Sears or Ace and buy a quality tap. Cheap taps are nothing but trouble.
    Mel, Ken, Peterb and 1 others like this.
    Massachusetts
    124
    THX.
    It an M6 x 0.75. Sears near me didn't have. My Harbor Freight kit does, but the threads of the tap are messed up - little burrs in the edges. I'm not going to bother with the cheap stuff anymore.
    McMasters has a set of three for $30+, other online sources are around $10. Graingers has a nice one for the aerospace industry - $75!!! I guess thats why military ashtrays cost $400 - the mil-industrial complex over charges! (1)
    THX for the help.
    JG
    (1) actually there is a real reason. Best definition I've heard was here -
    Ken likes this.
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    I don't see any reason not to chase it out. I would check the adjuster screw too and make sure that isn't bunged up. I live not to far from you and i may have the proper tap at home. I can take a peek after i get home. Im in Kansas City right now and i fly home tonight, i can check tomorrow.
    littletommy likes this.
  1. The Train Thread
    By Fred in forum Off-Topic
    Last Post: 10-06-2015, 09:42 PM
  2. The Irony thread.
    By Borneo in forum Off-Topic
    Last Post: 12-09-2014, 09:30 AM
  3. Poletics Thread
    By fielding in forum Off-Topic
    Last Post: 08-19-2014, 02:44 AM
  4. Looking for thread on here can you help?
    By skippyboyo2 in forum General Discussion
    Last Post: 04-29-2014, 02:39 AM
