highbeam problem
Results 1 to 5 of 5
Like Tree2Likes
  • 1 Post By rbm
  • 1 Post By SportsterDoc
Thread: highbeam problem
    Senior Member Michael Bryce Winnick's Avatar
    Oct 2015
    841
    highbeam problem
    This is on my 2013 Bonneville, not my TW, but can you help me out please.
    I did Lake Superior on my Bonneville over the weekend. I had nine hours left to make a 5 hour ride for Iron Butt. Should have been an easy qualifier. At nine o'clock I hit the Michigan line and it gets dark then comes pitch black and pouring rain. If I touch my passing light or high beam the fuse blows and then bike will not start. I ended up in a hotel and rode home the next morning. Now the passing light does not work at all, but the city light will stay on. If you touch high beam the fuse blows and bike will not start. What is this?????
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Either a bad/defective bulb or a direct short in the lighting circuit. I'd replace the bulb first.
    socalnative likes this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    Can you ride in the dark?
    Phelonius
    Nov 2016
    So. California, inland empire
    309
    I've had H4 bulbs melt down and become a short to ground situation. I always take the bulb out and look at it first thing.
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by socalnative View Post
    +1
    If fuse does not blow, with bulb out, that eliminates hi/lo switch, hi beam wiring and H4 connector.
    A loose connection in the connector can lead to high resistance and hi load.
    If the connector needs replacing and one not readily available, you can use 1/4" spade crimp-on connectors, preferably insulated (see attached photo)
    If replacement of connector is necessary, note which wire color goes to which connection.
    Or, see this link, which does NOT depict Yamaha wiring
    http://www.mypage.tsn.cc/roddqld/soc...ng_diagram.jpg
    The two parallel sockets are lo and ground.
    If you reverse (left & right) position, hi will not work.
    Tweaker likes this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  1. Carb Problem
    By Maulepilot in forum Technical Help
    Last Post: 07-14-2015, 10:14 PM
  2. electrical problem
    Last Post: 10-07-2013, 10:41 PM
  3. A problem with my new TW
    Last Post: 12-09-2012, 05:22 AM
  4. Carb problem, I think?
    By surfmansd in forum Technical Help
    Last Post: 02-19-2012, 09:07 AM
  5. I think I have a problem
    By n2o2diver in forum General Discussion
    Last Post: 12-20-2011, 06:16 AM
