Mystery Carb Connection
Results 1 to 5 of 5
Like Tree5Likes
  • 1 Post By steelhorse83
  • 4 Post By elime
Thread: Mystery Carb Connection
    Junior Member steelhorse83's Avatar
    Jun 2017
    3
    First, let me say that I'm new to the T Dub, and I've already learned a ton by reading through a bunch of great postings on here. I just picked up a used '97 non-CA model, and I'm working to clean up a few things on it. While working on getting the carb set right, I noticed a shiny brass fitting with no tube attached to it. It leads me to believe something is supposed to be there. Can anyone tell me if/what is supposed to connect to it? I think I'll replace the aftermarket hose clamp while I'm at it
    Here's a pic.
    Thanks in advance!
    Cornelis likes this.
    6,961
    That is a vent outlet -- there are two, one on each side of the carb. Take about 9" to 12" of tubing and extend it down and back. Or what I do is have one hose go up and the other down.
    Jun 2017
    3
    Thank you elime! Much appreciated. The parts description is just "Pipe", which isn't helpful.
    Senior Member GCFishguy's Avatar
    Oct 2016
    Moncton, New Brunswick, Canada ehh?
    339
    Not sure how much you've dug around the site, but there's a thread all about running the hoses a different way to prevent dying out when going through puddles.
    If you search water crossing you'll find the thread, with pictures. My 2015 would die and stall in the middle of a puddle a few inches deep due to the splash blocking the vent lines. Did the mod explained in the thread, I can plow through a couple feet and it never misses a beat.
    *edit* Here's the link
    Jun 2017
    3
    Quote Originally Posted by GCFishguy View Post
    I'll have to check that out. Thanks!
  1. Air Filter Connection Hose
    By Super Dooper in forum Technical Help
    Last Post: 04-05-2017, 06:11 PM
  2. Accessories and boredom and an internet connection
    By ToolmanJohn in forum General Discussion
    Last Post: 12-17-2016, 04:45 AM
  3. I lost my connection to the Forum.
    By Roninboise in forum General Discussion
    Last Post: 07-16-2012, 01:31 PM
  4. Replies: 6
    Last Post: 10-17-2011, 12:24 PM
