CDI repair - Page 2
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 103
Like Tree249Likes
Thread: CDI repair
  1. #11
    Senior Member Dell's Avatar
    Aug 2012
    139
    This is great! Where were you when I needed you? I have a spare since this is such a problem. A while back, there were attempts to address this on this forum, but never got much beyond the silicone that I recall.
    littletommy and jtomelliott49 like this.
  2. #12
    Senior Member tombauer's Avatar
    Jun 2017
    Sadly, Maryland
    142
    if there were any serious threads about someone making a replacement. if you could please refer me to that thread that would be great, all i find are dead ends and people giving up. next time someone needs one let me know and i will make a prototype. i already have all the software and hardware they use.
    tom
  3. #13
    Senior Member WECSOG's Avatar
    Jun 2015
    2,417 miles from LT! ;-]
    722
    Just a question, no offense intended but do you have any references for actual TW CDIs you have repaired? Reason I ask is the only thing I find about you is Honda tractor CDI repair on tractor forums and ebay. There does seem to be some crossover between Honda tractor and Honda motorcycle CDIs, but those CDIs are much simpler than a TW CDI because their static timing is where it should be, while Yamaha set the static timing of the TW such that only a microprocessor controlled CDI will work.
    I'm not saying you don't possess the capability to rebuild a TW CDI. I'm merely asking for references if you do have experience with these specific CDIs.
    '87 TW200
    '94 Sportster 1200
    '74 XL70 Frankenbike
    '76 CT90
    '72 CT70
    '72 XL250
  5. #14
    Jun 2017
    Milwaukee, WI
    1,176
    After all the CDI nightmares I've read about on here, I'm filing this under - good shit to know when it happens to me.
  6. #15
    Jun 2017
    Sadly, Maryland
    142
    TW and BW CDI's do not use a microprocessor. They use a crude time delay with a quad op-amp at its heart. Honda mower CDI's use a dedicated time delay IC but much the same result. I have true microprocessor controlled CDI's for 1985 to 2000 BW and TW bikes. Need some people to test them on actual bikes and report the timing just for fine tuning of the curve.
  7. #16
    Senior Member Lyterx's Avatar
    Jun 2014
    Etters, Pa
    471
    Quote Originally Posted by tombauer View Post
    T Need some people to test them on actual bikes and report the timing just for fine tuning of the curve.
    I have a 91 and will try one for you. My daily commute is 36-40 miles round trip mostly highway.
    1991 TW200
  8. #17
    Senior Member AGman's Avatar
    Nov 2013
    160
    XT200 is 35° @ 6000rpm while the AG200 is 29° at the same RPM if that helps. Don't have the specs for the TW200 but it would be somewhere around these values Id say considering they are the same top end. I may have the curves somewhere if I dig a bit deeper...
  9. #18
    Mar 2015
    Ynys Môn
    4,233
    TW200
    It might be worth trying to find the same information on the '87 TW, which were reputed, (according to our local donut dealer), to have the edge on acceleration, though they also had the tendency to wheelie easily if you goose it ....
    TW200 - 1998 - Japanese import - 5000 miles on the clock - TW225 Special Edition 2007
  10. #19
    Spokane, Washington
    17,091
    TW200
    Indeed, so be extremely careful ...
    1st John 1:9
    John 3:16
    John 3:17
  11. #20
    Jun 2014
    Bel Air Maryland
    4,166
    Welcome from Bel Air Maryland. Give me a shout if your in my area. We'll take a spin.
    If I’m ever on LIFE SUPPORT, UNPLUG ME. Then plug me back in... See if that works. Hidden Content
    TW 2006 Ruth
    TW 1988 Black Widow.
    1994 Harley FXR
    Rick
  1. '87 CDI Repair
    By radbuggy in forum Technical Help
    Last Post: 01-12-2016, 12:07 PM
  2. Helmet repair
    By SickPuppy76 in forum Technical Help
    Last Post: 09-07-2015, 08:31 PM
  3. Source Coil Wiring to CDI - GY6 CDI Troubles
    By Oleschool in forum Technical Help
    Last Post: 08-17-2015, 08:14 AM
  4. Exhaust repair (Help)
    By tcepilot in forum Technical Help
    Last Post: 11-10-2014, 09:58 PM
  5. Petcock repair
    By Tirebiter in forum Technical Help
    Last Post: 04-15-2013, 07:23 PM
news
