Which Oil Shifts the Smoothest
Results 1 to 7 of 7
    Member Hotrodjohn's Avatar
    Jul 2011
    DFW, Texas
    76
    What oil creates the smoothest shifting on the TW.? All of mine seem like they could be smoother. I am running Rotella 15/40
    87 (2) TW200 89 (2) TW200
    91 Honda XR250L
    97 Honda Valkyrie
    01 Kawasaki KDX200
    78 Suzuiki GS1000
    1970 (2) CT70H
    1974 Suzuki GT185
    1981 Honda C70 Passport
    Desert, SoCal
    7,369
    HRJ,
    FWIW these things are sensitive to chain slack when it comes to shifting. I run Rotella with no shifting issues, but back when I was burning up the standard chain poor shifting meant it was time to adjust the chain.
    BC
    537
    Mobil 4T
    I used Rotella for a while but couldn't stand the valve noise.
    Visit my Blog...Hidden Content or my YouTube channel: Hidden Content
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    Well I went with real Redline Ester Synthetic 10W-40 MC OIl
    Nicer but when poking around the forest breaking trail
    she overheats and basically STOPS shifting
    On my Vstrom I got an improvement with a small amount of
    Seafoam originally added as a pre change flush but
    noted improved shifting, fact, but not recommending to others
    Some bikes do react badly to chain tension either lose or tight
    Ester based synthetics tend to better shifting. Psuedo synthetics are not usually quite so good, but generally better than dino oils.
    Be careful with the newer versions of Rotella. Newer formulations are losing their ZDDP content in response to federal emissions regulations. The old formulations that have served so well for so many years are being phased out.
    Poway CA.
    2,099
    HRJ,
    I use 1qt of bananas!
    Senior Member atleastbehandy's Avatar
    Apr 2011
    Toronto, Canada
    250
    I have tried Yamalube, Mobil V-Twin, Motomaster, and Amsoil.
    favourite by far is Amsoil. Bike runs quieter (no more valve noise), doesn't lurch into first when cold, and neutral is easier to find.
    2005 TW200, 2" PowerMadd bar riser, Tusk D-Flex Hand Guards, PowerMadd Hand Muffs, Kick-Start, Valco Cup Holder, Givi E45N Top Case, Inline fuel filter, Storage Tube with MSR bottle, 45 Tooth sprocket, Stebel Low Tone horn, #130 Main Jet / no needle shims / 1.5 turns out on idle, Jimbo Shield, DID O-Ring chain, Clarke XT250 4.1 Gal tank, Custom Cycleracks
tw200 vtwin oil
what oil
