Missing rubber chain guard???? HELP
Results 1 to 9 of 9
Like Tree10Likes
  • 1 Post By Live2Ride
  • 6 Post By tok-tokkie
  • 2 Post By BkCntryCrwlr
Thread: Missing rubber chain guard???? HELP
    Member Live2Ride's Avatar
    SoCal High Desert
    39
    Help!
    I noticed that my 1987 TW chain started making a clanking noise on the last ride through the desert. I have it adjusted correctly yet it seems to be clanking on the swingarm right at the swingarm pivot. I was certain there was a black hard rubber piece that was on the swingarm to keep the chain from contacting the actual swingarm? If there was it is now gone. Honestly I just do not remember for sure and this time I can't blame my absence of mind on the booze!
    I must be loosing my mind because when I look at OEM diagrams of both the swingarm and chain drive assemblies it does not jump out at me.
    Can someone confirm or deny that this black rubber swingarm protector exists? Any idea on the part number at someplace like bikebandit.com or anywhere else? If it fell off with only mild off roading, this must be a common TW problem? Is there anyone or a link out there with a better fix for this issue? If a replacement is the issue, maybe some gorilla glue should be used to keep it on and in place?
    For now the TW sits in the garage to avoid damage to swingarm or frame.
    Ken likes this.
    Lyall
    Senior Member trailboss's Avatar
    Sep 2010
    Alexandria VA.
    140
    Hello. The part you're looking for is on bikebandit.com the swingarm diagram part #14 on the picture.Same thing happened to me you've got to take the swingarm off to do it. I used an old handgaurd cut down n wrappred it around the swingarm in the areas that looked like they make contact. A cheap and quick fix so I can ride till colder weather and I'll replace it then.
    Ephrata, WA
    1,125
    73 Trailboss nailed it. Its called (in the microfiche) a Seal, Guard. Its not black, rather its a khaki or nude color.
    1990 TW200
    Member tok-tokkie's Avatar
    Cape Town, South Africa
    88
    I lost mine too. It went through the front sprocket & de-railed the chain. The problem is it is held on by only 1 screw. Loctite that screw.
    I posted this on the old board.
    Chain Wear Strip.
    The chain wear strip is held by a single M5 bolt. That bolt came loose while I was, fortunately, riding close to home. The bike was only a few months old at the time. It then got dragged by the chain into the front chain sprocket which proceeded to chew it up but the chain got derailed in the process. I heard peculiar noises and no drive so coasted to a stop and soon saw what the matter was. I phoned my wife who came & collected me. I went back with some tools. Luckily I had been a member here a while & had learned that you need to lay the bike flat on its right side; then you can take the sprocket cover off without the engine oil all running out. First I took the battery out then did that and extracted the chewn up chain wear strip.
    The chewn up wear strip is at the top. At the front is the one I made. On the left is the chain guide I also made which I will write about when it is completed.
    I went to the local (good) Yamaha agent but felt the replacement was expensive & it would be some time before they could get me one as it is not something they had previously needed to supply. I am now retired but my last occupation was making industrial machine spare parts on a CNC machining centre I still have. I thus have the facilities for making a replacement. The original is some rubbery material. I decided to make mine out of UHMWPE
    Ultra high molecular weight polyethylene (UHMWPE), also known as high-modulus polyethylene (HMPE) or high-performance polyethylene (HPPE), is a subset of the thermoplastic polyethylene. It has extremely long chains, with molecular weight numbering in the millions, usually between 2 and 6 million. The longer chain serves to transfer load more effectively to the polymer backbone by strengthening intermolecular interactions. This results in a very tough material, with the highest impact strength of any thermoplastic presently made. It is highly resistant to corrosive chemicals, with exception of oxidizing acids. It has extremely low moisture absorption, has a very low coefficient of friction, is self-lubricating, and is highly resistant to abrasion (15 times more resistant to abrasion than carbon steel). Its coefficient of friction is significantly lower than that of nylon and acetal, and is comparable to that of Teflon, but UHMWPE has better abrasion resistance than Teflon. It is odorless, tasteless, and nontoxic.
    Source: http://en.wikipedia.org/wiki/UHMWPE
    It is something I have used a lot in my business career.
    Here it is fitted to the rear fork. Notice that I have changed the design so that it now goes right around the bearing tube so even if the screw falls out again it cannot come loose.
    SoCal High Desert
    39
    Quote Originally Posted by 73 Trailboss View Post
    Thanks for the confirmation. I suspected part #14 and will likely have to order one. In the meantime I like your quick fix idea which should allow me to ride pending delivery of the pricey chain wear strip. The post tok-tokkie provided looks like the ultimate set up and since he is retired hopefully he has cranked out a few extras to sell??
    Thanks again!
    Lyall
    SoCal High Desert
    39
    Thanks to all!!!!!!!!! The TW is a great bike, but the forum makes it really great especially since we are all short on the dollar these days. The brass at Yamaha should monitor this forum and with the feedback and upgrades noted; they could build an even better bike that would boost the bottom line at Yamaha.
    Ken likes this.
    Lyall
    Senior Member Tallahasseetw's Avatar
    Feb 2016
    Tallahassee, FL
    176
    anyone know what size screw this is?
    "suck, squeeze, bang, blow"
    Senior Member BkCntryCrwlr's Avatar
    Mar 2014
    Boise, ID
    416
    If you can wait three weeks, there is a cheaper Chinese version of this on ebay, I can't speak to the longevity since I just installed it. It does look and feel just like the factory one it replaced.
    JOINT PROTECTEUR CHAIN SLIDER YAMAHA TW125 TW200 TW225 SLIDER | eBay
    By the way tok-tokkie, nice fab job on your better than Yamaha grade replacement one you made. Impressive!
    Tweaker and Ken like this.
    You can't see it if you're not out there living it!
    '94 Rainbow Warrior - not so rainbow any more - Clarke XT350 tank, Lizrdbrth's seat mod, Beer Trap Pegs, Ricochet skid plate and more.
    Going through withdrawals, sold my other two TW's, down to one....Uhggghhh! Hidden Content
    Member SuperSport's Avatar
    Jul 2017
    49
    Quote Originally Posted by tok-tokkie View Post
    @TOK-TOKKIE , do you happen to still have the CAD file for that larger guard? Id' like to try converting it to 3D Printing and see if I can print one. That is if you don't mind sharing it. No problem if not, I'm just really new to 3D Printing, so I'm not very good at designing things.
    Disclaimer: These are my own opinions & not an official statement of Acme Corporation or any Acme employees. Actual mileage may vary. Price does not include tax, title, or license. Some assembly required, each sold separately, batteries not included. Objects in mirror are closer than they appear. If conditions persist, contact a physician. Do not pee into Wind. Call doctor for erections lasting more than 48 hrs; & Guiness Records. If you already pee'd into the wind, change clothes immediately.
  1. Chain Seal, Guard installation
    By mkriley in forum Technical Write-Ups
    Last Post: 05-26-2013, 11:00 PM
  2. Rubber Windscreen - and Rubber on Cyclerack
    By APV1 in forum Performance and Customization
    Last Post: 11-12-2012, 06:54 PM
  3. Missing plastic/nylon part under chain maybe?
    By FredTW200 in forum Technical Help
    Last Post: 10-20-2012, 11:55 AM
  4. Chain Guard needed..
    By rastaman in forum TW200 Classifieds
    Last Post: 02-04-2012, 02:57 AM
  5. Unknown Rubber Part
    By ravenwoods in forum Technical Help
    Last Post: 06-22-2011, 08:26 AM
1989 tw200 chain guid
lower chain guide yamaha tw200
piece of rubber missing off of chain
rear chain guard yamaha tw200
tw200 bottom chain guide
tw200 chain
tw200 chain guard
tw200 chain guard bolt size
yamaha tw200 chain guard
yamaha xt350 chain slider
yamaha xt350 chain slider seal guard
yamaha xt350 front chain slider
