Low speed jet plugged
Results 1 to 10 of 18
Like Tree29Likes
Thread: Low speed jet plugged
    Junior Member Gerald's Avatar
    Aug 2014
    saskatchewan
    11
    I took apart my carb this past weekend on my 2006 tw200 and found that my low speed jet was partially plugged. I cleaned it and i was amazed how much more power and response I have. I did the same to my sons 2010 Honda crf80 and his was plugged and it brought his bike back to life. I notice that both low speed jets had like a web or screen halfway down the jet before it sprays through the tube of the jet. Has anyone drill out this screen or web to prevent future plugging?
    Ken likes this.
    Senior Member DARIVS ARCHITECTVS's Avatar
    Nov 2016
    Ramsey, MN USA
    104
    I dunno.. having that web there prevents any particles from getting through, but does present the issue of maintenance to insure that it stays clean and clear. I would think routine checking of the strainers is needed until you discover the source of the contaminants (rusty/dirty fuel tank and bad fuel filter?).
    Ken likes this.
    DARIVS ARCHITECTVS
    (Darius the Engineer)
    1944 DKW NZ350-1 11. Panzerdivision
    2003 BMW R1150GS Adventure
    2010 Yamaha TW200 (cuz it's cute)
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Quote Originally Posted by Gerald View Post
    ....... I notice that both low speed jets had like a web or screen halfway down the jet before it sprays through the tube of the jet. Has anyone drill out this screen or web to prevent future plugging?
    Are you sure?
    I have not seen a screen in the slow speed jet (pilot jet) in a Teikei carb.
    I would post a picture but Photobucket is holding all my carb photos for ransom.
    ...figured out how to attach photo....
    jb
    Lyterx, Ken and Badgerflorida like this.
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,300
    The "web" is crap from the ethanol laden fuel we have nowadays, it's not supposed to be there....
    Dec 2015
    San Diego
    1,857
    What rbm says. I have found the blockage as soon as 2 months. It does look like a tiny web inside the jet.
    Ken likes this.
    Spokane, Washington
    17,260
    A little Lucus Deep System Fuel Cleaner or Seafoam once in awhile solves this problem.
    1st John 1:9
    John 3:16
    John 3:17
    Junior Member cowboybkr's Avatar
    Sep 2017
    1
    Hey guys, I'm having trouble getting my 2005 to crank and idle without the choke. Does okay at half choke. Immediately dies when I press the choke in. I have soaked the main jet , pilot jet, as well as the whole carb twice in chemdip, followed by warm water and compressed air. I can't get the smallest wire of my torch-tip kit to go through the pilot jet. I can barely see a hole at all. I suspect this is not normal. Can any one confirm? Has something fossilized in there? Should I take the smallest drill bit I can find and try to ream it out?
    Any input appreciated.
    littletommy likes this.
    Spokane, Washington
    17,260
    Welcome to the forum!!
    Typical signs of a clogged up pilot jet. Save yourself a lot of hassle and buy a new OEM one. If you can get some Lucus Deep System Fuel Cleaner it might help.
    Quote Originally Posted by cowboybkr View Post
    1st John 1:9
    John 3:16
    John 3:17
    6,957
    No screen in the slow speed jet. Here are a #36 and #45 from both ends. No screen.
    littletommy, admiral and jbfla like this.
    Senior Member methamphetasaur's Avatar
    Jun 2015
    Conifer, CO
    1,154
    On a semi related note, has anyone bought this from Procycle- and if so what sizes come with it? Alternately do you guys know any good places to but Teikei jets at?
  1. High Speed Jet #110
    Last Post: 11-04-2016, 06:04 PM
  2. Replies: 78
    Last Post: 08-08-2016, 05:46 PM
  3. Why is there a port plugged in the TW200 Carb?
    By travelrider73 in forum Technical Help
    Last Post: 07-16-2016, 11:40 PM
  4. High speed lag, not getting to top speed
    By jgaff in forum Technical Help
    Last Post: 05-11-2016, 10:03 PM
  5. Looking for a low speed trail bike, Sold on the TW
    By t556 in forum General Discussion
    Last Post: 06-08-2012, 06:12 AM
news
