main jet shim
Results 1 to 8 of 8
Thread: main jet shim
    Senior Member greendub's Avatar
    Montgomery, VT
    220
    Last weekend after a jet change my main fell out. Easy fix, but I noticed something. Bike ran great for the five minutes before. Climbing hills better than ever. Anyone ever try to put a small shim on the main jet? I have shimmed the needle, but am not sure if this would work. Looks like enough thread for 1 shim.
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I can't imagine what spacing it out would do
    I am not sure if the needle makes it down to the main jet or is riding in its own
    female part
    In either case
    I can believe as it backed out that some gas could flow around the looser threads
    and richen the mixture
    Aug 2011
    Cayce, SC
    3,109
    I would have to assume that adding another shim to the needle or going up a size on the main jet would be a better solution than trying to shim a jet.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Montgomery, VT
    220
    Agreed! But I am running a 125 in the old style. next size up is a 128 too rich. I run good at 75 plus degrees, but lean under that. Just a thought about the shim there. I spray foam, don't know much about any carb other than tw. Going to take all of my old jets 114 to 122 to a machine shop and have them drill the 114s that i have to 126 and 127. Got er dialed in warm weather, but 125 is lean in cold temps and perfect at warmer and 128 has always been too rich. Played with shims a bunch but never got em right. Now is best yet. Lots of playing since i put the big gun on. Added a db dog to quiet it down, but didn't quit make it rich enough.
    Montgomery, VT
    220
    Would it make a difference if it was deaper in the bowl?
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by greendub View Post
    Yeah... deeper... that is all a shim on the jet would do.
    You would just be that much closer to any gunk at the bottom of the float bowl.
    Changing the float height would accomplish the same thing.
    Stephen S.
    '07 TW200:
    Senior Member TWBARR's Avatar
    Jul 2011
    IN
    186
    Anyone know if fiber washers would hold up in the carb? Or would they fall apart. Thickness is .030"
    Mar 2012
    Boonville, No.-Calif.
    1,357
    It depends... mostly on the fiber material. As long as fuel would not attack it, maybe OK. But given time & vibration, it may degrade. Stick with metal. m.
  1. To shim or not to shim needle
    By kennethshaw in forum Technical Help
    Last Post: 01-26-2014, 01:32 PM
  2. shim sizes
    By raffles in forum Technical Help
    Last Post: 03-24-2013, 09:00 AM
  3. needle shim procedures
    By carp123 in forum Technical Help
    Last Post: 09-10-2012, 10:30 PM
  4. Just did the needle shim mod on my 88 dub have video
    By dz1 in forum Technical Write-Ups
    Last Post: 05-20-2012, 01:37 PM
  5. Carb shim/jet experience
    By yamamont in forum Technical Help
    Last Post: 10-10-2011, 06:03 PM
best size of needle jet shim xt225
mikuni pumper carb tm28 float height 17-19mm
needle shim
shim needle xt225
shimming needle xt225
xt 225 needle valve shim
xt225 float height
