Will it ever be "done"?
Results 1 to 10 of 10
    Senior Member twjay's Avatar
    Oct 2010
    Crosby, TX
    184
    I'm still working on changes to my TDub. It gets ridden 99% street now, so I'm making it as streetable as possible.
    I've changed to a K&N cone filter (ok... cylinder), diy header with the silencer off of a cr125, cut the airbox down to just a battery tray, changed to TW203-204 tires, and lots of other farkles here and there.
    Here it is as of now....I'm working on a set of highway pegs, but they're still in the design phase. I want to make sure they look nice.
    I also want to make a nicer looking exhaust system, but this one works fine for now.
    http://dl.dropbox.com/u/9481139/IMG_0105.JPG
    http://dl.dropbox.com/u/9481139/IMG_0106.JPG
    The images are pretty big, so I used links until I have time to edit/move them.
    Desert, SoCal
    7,369
    It'll never be "done". Give it up and roll widdit .
    Nice work.
    Aug 2011
    Cayce, SC
    3,109
    Looks good. And the answer is NO!
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Member shiftline's Avatar
    Apr 2012
    B.C. Canada
    97
    Nope, never ever done!
    Ephrata, WA
    1,125
    Nice looking bike. Your right side engine cover looks cool.
    1990 TW200
    Poway CA.
    2,101
    Great bike!
    Definition.............................Addiction
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    342
    looks really nice! I have thought I was done with mine several times already!
    Oct 2010
    Crosby, TX
    184
    Thanks for the kind words. There is still quite a bit I want to do with it.
    Oct 2010
    Crosby, TX
    184
    Member eventiller's Avatar
    May 2012
    PA
    35
    Impressive indeed. What did the headlamp assembly come from?
