Substitute for small carb needle spring?
Results 1 to 10 of 15
Like Tree28Likes
Thread: Substitute for small carb needle spring?
    Member like2wlz's Avatar
    Oct 2013
    89
    '05 TW. I managed to lose the small spring that sites on top of the carb needle and under the small white plastic cap. I wouldn't mind buying a carb rebuild kit to get a new spring but it isn't clear from the kit descriptions that this spring is included in any of them. Anyone know if the carb rebuild kits include this spring or know of any substitute? Reason I took carb off is the bike has an FMF power core and it runs really lean and hot at higher speeds. Spark plug grey, pops on decel. I drilled the main jet with a 1/16" drill which was the smallest drill bit I had and bought some washers to shim the needle a little - I couldn't find 2.5mm washers locally in stainless, only 3mm stainless and 2.5mm for zinc. Any opinion regarding using the 3mm washers which are only a little loose vs the 2.5mm zinc ones? I did order a 130 main jet but it won't come in until mid next week which is why I drilled the stock 126. I also removed the cap over the enriching (?) screw which was only 3/4 turn out and backed it to 2.5 turns out. Carb was pretty clean but I am soaking in Pinesol.
    littletommy likes this.
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    Rocky Mountain Atv. Has that spring in stock for $1.98. I would have added the link but I don't no how. Just go on there site and click on Oem parts and the put your bike in and go to Carburetor and there it is.
    littletommy, Tweaker and like2wlz like this.
    Spokane, Washington
    17,257
    https://www.rockymountainatvmc.com/oem-schematic/2
    Part #8
    OEM Stock Number 5LB-14275-00-00
    Click on Carburetor to view schematic
    Quote Originally Posted by cowboyjeff View Post
    1st John 1:9
    John 3:16
    John 3:17
    Oct 2013
    89
    you guys are the best. Ordered one, thanks
    Oct 2013
    89
    Well, of course since I ordered a new spring I found the old one. It had dropped/popped a couple feet from where I was working onto a tangle of lashing straps. I must have spent a couple hours looking for it including each individual strap and surrounding garage floor without any luck until I ordered the new spring, one last go thru on the straps and there it was on the floor. No worries, I'm glad to be able to put the carb back together today.
    I won't be surprised if the drilled out main jet doesn't work, there no concensus that I could find that says what orifice diameter is for each jet #. I have a #130 ordered if the drilled stock #126 jet doesn't work.
    The pilot jet was almost completely clogged and I couldn't pass a small copper strand thru it. Pinesol made it nice and shiny but still clogged. I had some all metal safe rust remover and soaked it overnight - now there is a perfectly round looking tiny central orifice, maybe the rust remover helped or just more soaking.
    Keeping my fingers crossed that this all works out.
    before removing the carb I replaced a slipping clutch pack with EBC that included new clutch springs, great improvement and now the friction zone feels more like other motorcycles, not just the on/off that the worn clutch had.
    littletommy, Fred, jbfla and 2 others like this.
    18,561
    Glad you found the spring. Otherwise I was going to suggest a section of ball point pen return spring or simply a solid block of anything of the correct height. The compressible spring of the stock unit is simply to take up excess free play depending on how many shims one has, it was a cheaper option for Yamaha than having it’s jobbers mill grooves and supply cir clips for their supplied needles like those featured in the majority of other carburated motorcycles. Anything that fixes the needle in position so it does not ride up in the bakelite slider to the top of the white cap will work...glue, a piece of toothpick, piece of zip tie, tubing, a rock, a wad of plastic bag. Whatever works, no need to pay $15 shipping for a $2 spring. This is not rocket science, just a simple constant velocity carb.
    Note: Without the spring the TW will often start up and run just fine until at some point opening the throttle will raise the needle and then without the return spring the needle may not re-set itself resulting in a suddenly seemingly inexplicable rich fuel mix as the needle remains hung up...the big spring pushes the bakelite piece down just fine, but need the little spring, or something similar, to keep the needle held down inside the bakelite.
    like2wlz and cowboyjeff like this.
    Oct 2013
    89
    Good to know Fred, I was thinking of the pen spring, the ones I pulled from pens were larger but still seemed to fit the top of the needle and the plastic cap but I wasn't sure what the spring was there for - thanks for clearing this up, it'll likely help someone else down the road.
    The bike starts and runs great low speed but boggs with higher throttle so I overdid things. I'm curious to see the diameter of the #130 jet that is coming and I take things step wise after replacing the jet instead of going all in. The carb base gasket wasn't that great so I coated it with a thin layer of permatex non-hardining gasket maker. No leaks but I'll have to pull it off again when I change the jet out, do you think it will be better to just replace the gasket next time?
    18,561
    If readily available I would replace the float bowl’s gasket ( one side needs to face up, make sure yours is not up side down) if only to avoid the mess of re-newing the Permatex.
    I misplaced this spring too the evening before I departed for Moab2016 when in my darkened garage I decided at last minute to add a shim based on a fellow forum member’s strong recogmendation. Missing spring darn near ruined a week long group ride.
    I subsequently removed the shim in order to restore reasonably lean jetting for higher elevations.
    cowboyjeff likes this.
    Nov 2013
    West Jordan, Utah
    207
    like2wiz check this Jet size chart out. 49ccScoot.Com : Printable Drill Bit Size Chart
    like2wlz, Fred and littletommy like this.
    Oct 2013
    89
    I saw a chart like that but then also read that jet size wasn't always same as mm diameter in thousands. I used a 1/16" drill which would be a #158. That explains the bogging. For fun I might solder the jet and get some small dremel drills to redrill it smaller and see what happens since my #130 jet won't be delivered until mid week. I did remove the washer from the needle and turned the pilot screw to 1.5 turns instead of 2.5 (stock was at 3/4 turns out). Runs great at lower speeds but bogs down higher speed currently.
    Tweaker likes this.
  1. WTB Carb Needle Shims
    By Jut8 in forum TW200 Classifieds
    Last Post: 02-22-2016, 05:37 AM
  2. Base Line Carb needle setting, PICS of Carb? 1989 TW200
    By YankeePrepper in forum Technical Help
    Last Post: 04-24-2015, 05:04 AM
  3. carb needle shims
    By aladdin in forum Technical Help
    Last Post: 03-02-2013, 10:55 PM
  4. Help removing needle from old style carb
    By kennethshaw in forum Technical Help
    Last Post: 04-18-2012, 05:13 AM
  5. Carb Needle Shim Question
    By sfsccoter in forum Technical Help
    Last Post: 09-16-2011, 12:05 PM
small carb sping and needle
