no start - yes start - lucky guess
Results 1 to 10 of 10
Like Tree30Likes
  • 3 Post By Yam200
  • 3 Post By CS1983
  • 3 Post By RockyTFS
  • 7 Post By elime
  • 5 Post By Yam200
  • 2 Post By Fred
  • 4 Post By elime
  • 1 Post By CS1983
  • 1 Post By phelonius
  • 1 Post By stagewex
Thread: no start - yes start - lucky guess
    Member Yam200's Avatar
    Nov 2016
    Colorado
    45
    after a +2000 mile trip residing on the rail on the front hitch mount does not start. Turns but does not fire. Gas? Yes - hear it swooshing around. Full choke: No go. Half choke: No go. No chocke: No go. Giving gas: No go. Plug out: Looks good. Starter fluid into cylinder, plug back back in and fires - die again. Sounds like no gas to the carb. Switching selector to off, to gas, to reserve. Low and behold: Fire in the cylinder at the reserve setting! Once running back to normal gas - setting and she purrs like a good kitten - success. Can't make sense of it but whatever works. Just wanted to share: If she ain't starting switch to reserve even if there is still gas in the tank?!
    Senior Member CS1983's Avatar
    Aug 2011
    Tulsa, OK
    634
    hrm... could something have clogged in the petcock and when you switched to reserve, it flushed it?
    switching back, the clog would have been gone.
    Hidden Content Hidden Content
    "I thought the slowest bike i have ever owned was going to kill me." - Hidden Content
    The John Birch Society is too Liberal.
    Hailey, ID
    3,376
    Time to pull the tank and remove the petcock and flush both thoroughly.
    jtomelliott49, Ken and Fred like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    6,981
    One of my "rules" is when ever anything goes wrong with the engine switch to reserve. It is simple, easy, free, and quick to do and I bet works half the time.
    I came upon a dirt bike rider kicking and kicking and no start. I asked "Did you switch to reserve?" "Ah, no." I suggested he try it, he did, and it fired up.
    Nov 2016
    Colorado
    45
    One thing I learned from this experience: Obviously I was lucky with the "reserve" setting. Relying on the "swooshing of fuel in the tahk" is not a test to check for enough jiuce. I just filled up - was low. Even though my trip meter, set to Zero last time I filled up, only showed 68 miles. elime seems to have had a like happening. If she don't start switch to reserves before getting into more elaborate diagnosis. Did you check your GAS (in the tank, I mean ...)?
    jtomelliott49, Ken, Fred and 2 others like this.
    18,809
    We don’t always confess to forgetting to switch to reserve but rest assured you are not the first to be in this situation.
    At least you weren’t ten miles down the trail when the fuel ran dry.
    Ken and jtomelliott49 like this.
    6,981
    What really hurts is when the tank is on reserve and you fill it up and forget to switch it back. Surprise, surprise the next time you run out of gas.
    cowboyjeff, admiral, Ken and 1 others like this.
    Aug 2011
    Tulsa, OK
    634
    Enter ye olde MSR fuel bottle and/or rotopax
    jtomelliott49 likes this.
    Nov 2010
    Frostbite Falls Ill
    2,719
    I can't switch to reserve. There is no reserve on my Suzuki Van Van. Come to think of it, there is no petcock under the tank either.
    This vehicle is stock and has not been modified. It is less than a week old.
    Phelonius
    Jun 2016
    New Rochelle, New York
    1,773
    Sometimes a big deal running out of gas on an efi bike as the fuel lines feed air into a system that shouldn't have any. Even and extra bottle of fuel may not start your bike without priming the system. And of course no reserve. So keep your eye on your miles. If it comes with a fuel light (this for any bike) never trust it.
    Here's a pix of a Blue VanVan on the Suzuki site. Very pretty:
    Suzuki Cycles - Product Lines - Cycles - Products - RV200 - 2017 - RV200
  1. Won't Start - Lights all die when start engaged
    By vuldub in forum Technical Help
    Last Post: 09-14-2016, 09:39 PM
  2. I had to start somewhere
    By troll in forum Performance and Customization
    Last Post: 05-11-2014, 08:18 PM
  3. Start but no start - please help -
    By rtf in forum Technical Help
    Last Post: 05-23-2013, 08:24 PM
  4. TW no start
    By immgunn in forum Technical Help
    Last Post: 07-03-2011, 07:28 PM
  5. kick start won't start
    Last Post: 01-15-2011, 05:23 AM
