Bike stalled on the highway
Results 1 to 10 of 12
    Senior Member Guitarman's Avatar
    Jan 2012
    Trois-Rivieres, Canada
    167
    Here is the story.
    I took my bike to go to work this morning. I rode it for about 2 minutes total. After I reached 60mp/h on the highway the bike stalled. Same thing as when you run off of gas. I pulled on the side, checked thank and fuel line, everything was fine (tank was full). Tried to start the bike, it cranked but didn't want to fire.
    I turned around, pushed the bike for half a mile or so trying to start it every 2 minutes (one try at a time) and it finally fired, I was half way back home.
    Last time it did similar thing was when I let it sit for a week. When I tried to start the engine, nothing happened. It would spin but no gas was getting to the cylinder. I put a small drop of fuel directly in the spark plug hole and it fired up right away and kept going. I had to do the same thing when I first started the bike after winterisation.
    My guess is that there is something clogging the carb. Fuel flows freely from the petcock, so it's not the cause here.
    I will clean the carb this afternoon for sure, but I want to know if you guys have an idea of what else could cause similar issue.
    The spark plug is new and was working fine every time I checked it. I rode the bike in a big storm yesterday and maybe water got somewhere it shouldn't have??? TW fired up just right this morning before the happening of the stall.
    Thank you for your help
    Sounds like a fuel flow problem, and you've narrowed it down to the carb.
    Sep 2011
    Southcoast MAsshole
    2,661
    Senior Member DRF64's Avatar
    Mar 2012
    Kalamazoo, MI
    136
    Seems to be an epidemic of this lately. I'm getting a little nervous.
    Jan 2012
    167
    Thank you guys!
    Anyone knows the correct way to remove the float pin? Mine seems stuck and doesn't move when I push the smaller end...
    Jan 2012
    167
    I had a look at the air cleaner. It was really dry and there was some crap/sand at the bottom. Maybe that can be the reason behind that fuel problem...
    Jun 2011
    Dothan, AL
    1,715
    Read this thread it cover float pin removal.
    https://tw200forum.com/index.php?/top...buretor-float/
    2005 TW200 (SOLD)
    2013 DR650
    Member Hotrodjohn's Avatar
    Jul 2011
    DFW, Texas
    76
    Quote Originally Posted by Guitarman View Post
    Sand in the airbox wont clog a jet because the air is coming through above it, but will scratch your cylinder. Get a new oem filter, oil it up and install, otherwise they run lean. If you have good flow at the petcock, Check the fuel inlet at the float needle, there is a little screen that will clog and restrict fuel to the bowl. If it isnt the fuel or carb it sounds ignition related.
    87 (2) TW200 89 (2) TW200
    91 Honda XR250L
    97 Honda Valkyrie
    01 Kawasaki KDX200
    78 Suzuiki GS1000
    1970 (2) CT70H
    1974 Suzuki GT185
    1981 Honda C70 Passport
    Jan 2012
    167
    n2o2diver, how could I have missed this thread!!? I must get more proficient with my searches..
    Jan 2012
    167
    Hotrodjohn! What a coincidence! I was about to quote one of your previous post and you replied to mine while I was typing!
    "My 89 TW would run perfect unless you held it at 60 plus for a minute or two and it would die as if starving for fuel. That turned out to be a clogged inlet screen on the float valve. Seems both the petcock screens and the float inlet screen will gum up over time. It would let enough fuel in if the demand wasnt too much, but wide open for any length and it was too restricted to keep the bowl full."
    https://tw200forum.com/index.php?/top...your-too-lean/
    Thank you for your help ;-)
  1. stalled out, bummer.
    By phazer in forum Technical Help
    Last Post: 12-03-2016, 09:48 PM
  2. YZ250f on the highway?
    By jckosnow in forum Off-Topic
    Last Post: 03-30-2013, 04:39 PM
  3. Bike stalled update
    Last Post: 11-17-2012, 09:56 AM
  4. Bike stalled
    Last Post: 10-22-2012, 04:32 PM
  5. can it hang on the highway
    By hoofhearted in forum General Discussion
    Last Post: 02-09-2011, 04:52 PM
