Oil change - switch to synthetic?
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
    1993 TW200 in Meridian, Idaho
    1,533
    I'm hoping to do an oil change this weekend. At the risk of starting a "great debate", should I switch to a synthetic oil? I've been using good old Yamalube from the dealer in the past. I'd say the bike could shift a little easier than what it does. I've adjusted the chain and that helps, but occasionally find things a little rougher than I'd like. With Synth oil help? If so, which would be a good choice? Other than draining out the old stuff, if there anything else to consider when making the switch?
    No real need to reply I guess. I see I should've searched the topic before this post. There's more reading on the subject than I have time for already. Reply if you like, but no sense in beating this horse anymore. I'd delete this post were that possible. Forgive the intrusion and return to your normal programming.
    Technological advances in cleaning up dino oils have brought base stocks pretty close to ester-based synthetics, but the cost has also risen. Pretty much the new technologies do a better job of removing impurities and rearrange the dino molecules closer to true synthetic. Any synthetic specifically for motorcycles in the proper viscosity for your weather and riding style will do. I use Mobil 1 because I found good quantities at a very good price. Royal Purple, Redline, and Amsoil are also very good, but prices are high. These four lead the pack in lab and real-world testing, but the others are catching up.
    Avoid oils intended for diesels. Recent formulation changes have left these oils with insufficient ZDDP to protect TW cams and rockers, and additives that improve fuel efficiency put TW clutches at risk. Your national government at work, making life difficult.
    Sep 2011
    Southcoast MAsshole
    2,661
    my 00 had a little over 8k miles when i got it last spring...i wasn't even sure what the 2 previous owners used but i did an oil change right away using synthetic mobil 1 4t...i used this same oil in my 05 cbr 600rr...switching from regular oil to full synthetic made a difference in shifting smoothness on that bike so i figured i'd use it on this bike...i'd say do it but don't flip flop, if you go synthetic stick with it
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    I have a bottle of mobil 4t racing sythetic on my counter. Hoping it will cure the hard to get in neutral when engine is really hot problem. Adding an oil cooler is on my to do list too.
    Senior Member Roninboise's Avatar
    Feb 2012
    Boise, Idaho
    239
    I have put on about 500 miles since I purchased my TW 2005. I changed the oil as soon as I brought it home from Utah. It had 1000 miles on it and probably the original oil in it. I did the first oil change with Yamalube 20-50. Since most all of my riding is trail riding, I found that shifting from 1st to 2nd and back has at time left me in a predicament; neutral and a gravity induced reverse, usually when I am going up something very steep. Those times turned out to be the least fun time of that particular adventure.
    I did research shifting on this forum and found the best recommendation to be a change to synthetic oil. Qwerty seems to be a very thorough in his research. So I have found that following his lead is a good way to go; so this morning I went over to O'Reily's and got a quart of Mobile 1 Racing T4 10-40 oil. As I type this, the old oil is draining. I will give an update on the Mobile 1 perfomance after our next ride which looks like next week.
    Happy Trails All
    Ron in Boise
    1,533
    Quote Originally Posted by Ron in Boise View Post
    Happy Trails All
    Ron in Boise
    Senior Member Bagger's Avatar
    Jan 2011
    Central WA
    1,050
    Hey True,
    No worries.
    One vote for Amsoil here. I use it in 17 different vehicles and use their grease/lubes. In consideration of this, I have been a T1 certified dealer for 15 years.
    No, I don't hawk the oil, but for the annual cost of my dealer license I get a significant enough price break that it makes Amsoil competitive with conventional oil costs.
    I have several buds that use it as well, and we combine purchases which saves us more on shipping/group rates.
    Along with the purchase price savings, I make more than enough commission off just my own purchases to more than renew my annual license . . . it's a good merry-go-round.
    Just a thought on saving some money and still taking great care of your rigs. And it works even better if you have some friends local to share benefit/cost with.
    Bag
    "The TW may be slow, but the Earth is patient" - MK
    "If I'm wrong, and it turns out that you hate it, I'll send you all my Barry Manilow albums." LB
    Member koonercat's Avatar
    Mar 2012
    Pa
    78
    Yamalube out and Amsoil in just 2 days ago on my new '06 with 4K miles. Much quieter engine and much smoother shifting.
    BTW I used 20-50 because I could get it local. $10 a quart.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,389
    Quote Originally Posted by Truelight View Post
    ... should I switch to a synthetic oil? ...
    yes...
    RTG
    RTG is offline
    Senior Member RTG's Avatar
    New Jersey
    446
    Great topic!
    I've been thinking of making the switch myself.
    Does any one have any experience with Motul and or Bel Ray synthetic?
    A TON of guys were using Motul Synthetic in there motorcross bikes when i was hanging around and riding some of the MX tracks in SoCal.
    Kinda made me wanna put some in my TW and make the switch.
    -Todd
    "I've often said there's nothing better for the inside of a man than the outside of a motorcycle"
  1. Synthetic???
    By Woodi23 in forum General Discussion
    Last Post: 04-16-2013, 07:27 PM
  2. Mobil 1 v-twin synthetic 20w50
    Last Post: 04-26-2012, 07:00 AM
  3. synthetic oil
    By thumper in forum Technical Help
    Last Post: 10-23-2010, 11:18 PM
  4. Any experienced clutch slipping with synthetic oil?
    By catamount in forum Technical Help
    Last Post: 10-05-2010, 03:15 PM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 06:50 AM
2012 tw200 oil
change oil in a tw200
should i use synthetic oil in a yamaha tw 200
tw 200 oil
tw 200 oil change
tw200 forum oil change
tw200 oil
tw200 oil change
tw200 oil synthetic
tw200 royal purple
tw200 synthetic belray
tw200 synthetic oil
