rear shock squeak
Results 1 to 7 of 7
    Junior Member sdim66's Avatar
    Apr 2012
    14
    Anyone have any experience with the rear shock squeaking? Its is bad and is driving me crazy. I cannot figure out for the life of me exactly where it is coming from. I took the seat off to get a better listen. I've dripped some WD40 on a few spots, but no luck. I didn't want to just spray willy nilly the entire shock, but I'm thinking that might be the only solution. Its not an easy area to lubricate without dismantling more stuff. Its the spring rubbing against something is what seems to be happening. Any kind of lube I can safely spray in there to hopefully resolve? I don't think WD40 is a good option but its all I had on me. Ideally grease would probably be best option but I don't know where to grease it.
    Desert, SoCal
    7,369
    Have you ever lubed your swingarm bushings?
    Ephrata, WA
    1,125
    Good call.
    Also, you can remove the shock (its really not all that hard) and grease the upper bolt and lower pin.
    1990 TW200
    Aug 2011
    Cayce, SC
    3,109
    I had this issue a while back. Take off your seat and spray some wd around the top of the shock where it meets the frame. Do the same at the bottom. Spray as much as you want, it wont hurt anything.This should fix your problem.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Apr 2011
    Martinsville Indiana
    2,089
    Dont feel bad my 07 does it also. I havent sprayed it yet but i have lubed the swing arm bushings.
    Apr 2012
    14
    Used some paper towels to block any overspray and then shot a couple short burst of WD40 at the top portion of the shock and squeak was gone. Thanks for the replies.
    Apr 2012
    14
    I haven't. Its brand new bike... well, in theory... its an new 09 only 100 miles on it. Probably not a bad idea anyway to lube everything though.
  1. XT 350 Rear shock
    By Cretus in forum Performance and Customization
    Last Post: 06-27-2013, 11:33 AM
  2. REAR SHOCK
    By dutchbat in forum Performance and Customization
    Last Post: 02-14-2013, 11:08 AM
  3. Rear Shock
    Last Post: 11-01-2012, 09:19 PM
  4. REAR SHOCK
    By Gerry in forum Sticky threads
    Last Post: 06-05-2011, 07:38 AM
  5. Rear Shock Mod
    By wiigstyle in forum Performance and Customization
    Last Post: 10-27-2010, 11:58 AM
tw200 rear shock squeak
