Buzzing sound when attempting to start.
Results 1 to 9 of 9
Like Tree8Likes
  • 1 Post By zakmontoya
  • 3 Post By jtstdub
  • 1 Post By Purple
  • 2 Post By SportsterDoc
Thread: Buzzing sound when attempting to start.
    Junior Member zakmontoya's Avatar
    Feb 2014
    virginia
    22
    Well. The battery charger says I have a fully charged battery. The bike is 2013 with original battery. When I turn the key on, I get full headlights. Everything seems normal. Press the starter. Maybe one or two cranks. Then just a loud buzzing sound. When inspecting the terminals, I find just a small amount of corrosion on one terminal. Very minute. The buzzing seems to be coming from the right side of the bike, just forward of the battery. Any ideas? I'm pointing to the area that's buzzing in the photo.
    cowboyjeff likes this.
    Feb 2014
    virginia
    22
    I pulled the plastic on the right side of the bike. Checked the two 20amp fuses. They were fine. Inspected the plug between them. It's fine.
    Gonna pull the battery and take it to be tested.
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by zakmontoya View Post
    What is battery voltage, key off?
    What is battery voltage, key on?
    What is battery voltage while trying to crank?
    What is condition of both ends of both battery cables?
    For more info, see the beginning of post one of this thread:
    http://xlforum.net/vbportal/forums/s...1986193&page=6
    (after the beginning, it is primarily H-D Sportster specific)
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    I have never been able to get my Tw batteries to last 4 Years, Im betting your batterie is bad.
    Probably best not to let it buzz to much, might ruin the starter. Good luck.
    Jan 2015
    Fair Oaks, Calif
    500
    Teach yourself how to use a DVM! You will never have to wonder what is going on with a problem like this.
    Peterb, UncleRandy and Donzo like this.
    Mar 2015
    Ynys Môn
    4,550
    Sounds like your starter relay is on the blink .....
    Dryden-Tdub likes this.
    - Hidden Content
    Jan 2017
    Southern Nevada
    1,077
    May be, depends on available battery voltage:
    When the starter button is pressed (key on, off/run switch in run mode), voltage is sent to the relay, then to the coil of the starter solenoid. If the system voltage is normal, the starter engages.
    If the system voltage is low, due to low battery or faulty battery cables (the frame/motor end of the negative cable is a common issue), then the voltage may be sufficient to close the relay or solenoid coil, but when it closes the high amperage contacts from the battery to the starter, the low voltage has a compound effect:
    1. Lower voltage is a challenge to the starter turning over the motor and
    2. Lower voltage results in a higher amp draw for the motor to try to pull the same wattage.
    In a low voltage condition, once the starter tries to draw enough amps to turn over the motor, the voltage drop is so excessive that the coil cannot remain energized and it opens the high amperage contacts to the starter. If the starter button is held, the voltage recovers (after the coil drops out) enough for the coil to again close and the cycle repeats until the voltage drop will not allow the coil to close. This is solenoid chattering.
    If the voltage is very low, there is only one click and there is not enough voltage for the coil to again energize.
    Tweaker and UncleRandy like this.
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
    Hailey, ID
    3,312
    Quote Originally Posted by SportsterDoc View Post
    For 50 years, I have always wondered just what exactly caused that! Now I know. Thanks Doc!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Jan 2017
    Southern Nevada
    1,077
    Welcome!
    2014 Honda CB1100
    2018 Yamaha XT250
    2017 Yamaha TW200
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  1. no start - yes start - lucky guess
    By Yam200 in forum Technical Help
    Last Post: 07-20-2017, 08:08 AM
  2. The Sound of Freedom
    By Fred in forum Off-Topic
    Last Post: 09-17-2016, 11:27 AM
  3. Won't Start - Lights all die when start engaged
    By vuldub in forum Technical Help
    Last Post: 09-14-2016, 09:39 PM
  4. Thunderbirds are buzzing me.
    By ZDR1 in forum Off-Topic
    Last Post: 02-02-2015, 08:33 PM
  5. kick start won't start
    Last Post: 01-15-2011, 05:23 AM
