stator and pulse
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By operose
  • 1 Post By Ayers Garage
Thread: stator and pulse
    Junior Member vincentdsnt's Avatar
    Jan 2011
    26
    What years cross on the stator and pulse with a year model 1987 and will parts from any other yamaha work as well? Thank You, Vincent.
    Jul 2011
    1,123
    Sorry Vincent, but the 1987 TW200 was a "one year" bike -- the parts you speak of do not interchange.
    If you get the stator, pulser coil, engine cover, and CDI from a later model bike it will work for you though with some "fiddling".
    I was also able to convert my bike to run on a yamaha TTR stator/pulser coil/cdi setup, and that was very cheap on ebay. It all depends on your mechanical ability/financial situation, I suppose
    WECSOG likes this.
    ITCB
    Jan 2011
    26
    Quote Originally Posted by operose View Post
    Jan 2011
    26
    operose, Thank You I know of an 87 for sale needing those parts in O K shape for $500, I think I will pass I would guess dealer parts will be costly.
    Senior Member greendub's Avatar
    Montgomery, VT
    220
    Just changed cdi, stator coil and pulser on my 87 into over 500 in parts after shopping around. Stator coil read out of spec on my ohm meter, but so did my new one. I have found that if you disconnect the brown wire on a bad cdi the bike will run. But don't ride it that way. Does the bike not start?
    Jan 2011
    26
    Quote Originally Posted by greendub View Post
    From what I am told it does not run everything is fine compression, carb so on, two techs the owner had check it said he needs those parts........
    Jan 2011
    26
    So greendub you are saying your problem was the cdi not the stator/pulser? If so I may need to buy your old parts. let me know you have them so sale?
    Montgomery, VT
    220
    Cdi i want to keep. I can sell you a pulser and stator coil but the wires were cut at the end. Bike had a mouse problem when i bought it. They read in spec. Sator coil reads out but same as my new one
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    Are the 87 stator and rotor mechanically different? Or is it just wiring?
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    Judging by the factory parts diagrams, the stator is significantly different beyond just the wiring configuration.
    The Rotor is Yamaha part number 3NS-85550-00-00
    It fits only the following...
    1986 BIG WHEEL ELEC START - BW200ES GENERATOR
    1987 BIG WHEEL ELEC START - BW200ET GENERATOR
    1987 TRAILWAY - TW200T GENERATOR
    1987 TRAILWAY - TW200TC GENERATOR
    1988 BIG WHEEL ELEC START - BW200EU GENERATOR
    The Stator is Yamaha part number 2JX-81410-M0-00
    The Pulser Coil is Yamaha part number 2JX-85580-M0-00
    The CDI box is Yamaha part number 2JX-85540-M0-00
    If fits only the following...
    1987 TRAILWAY - TW200T ELECTRICAL 1
    1987 TRAILWAY - TW200TC ELECTRICAL 1
    All of these parts are still readily available from Yamaha parts channels. The prices are generally the same as the 1988 and newer stuff which is obviously more common.
    WECSOG likes this.
  1. stator and rectifier
    By 671tdub in forum Technical Help
    Last Post: 05-29-2013, 10:25 PM
  2. Can I Upgrade a 90 stator?
    By John In NC in forum Technical Help
    Last Post: 05-10-2012, 07:16 PM
  3. need c.d.i. and stator for 88 tw
    By ranger11 in forum TW200 Classifieds
    Last Post: 04-18-2012, 05:26 PM
  4. Stator Function
    By jmurray in forum Technical Help
    Last Post: 07-12-2011, 09:10 AM
  5. Bad Stator????
    By dbreinich in forum Technical Help
    Last Post: 03-14-2011, 12:15 AM
1987 trailway 200 stator
1987 tw 200 stator
1987 tw200 new cdi box
1987 tw200 pickup coil
1987 tw200 strator and cdi box
1987 yamaha tw200 stator
bw200 pulser
how to check pulser coil yamaha bw 200
how to test a stator on bw200
tw200 stator coil
yamaha bw 200 testing pulser coil
yamaha ttr 125 bad stator
