Yamaha XT200J missing a gear
Results 1 to 10 of 13
    Junior Member laurent's Avatar
    Jun 2012
    3
    I was given a 1982 XT200J that the kick start would not work on. I removed the clutch side cover and found that the idler gear had nothing to engage with as someone removed the kick gear off the shaft of the Primary Driven Gear. I have tried to find a used one locally and on EBay. I did find one from Euro Spares in England but it is off a 125 and he will not ship international. I learned that the part number is 3NS-16150-00-00 and that they are available as an OEM from Yamaha. Problem is, they are over $200. John Groom from NW Vintage Cycle Parts in Estacada, OR took the time to tell me that the same primary driven gear fits many Trailway TW200 Yamaha bikes and early XT 125s.
    I would be very grateful if anyone out there has one or knows of someone who does. I have no idea why that gear is missing but the bike only has 3850 miles on it and I do believe she has a second life left.
    Laurent Perron
    Bergheim, TX (new San Antonio ... Go Spurs!)
    210-846-1688
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    Laurent, you might make it easier for someone here to help you if you do a bit more research at any Yamaha suppliers website. See what years of TW use that part number. Many here have 'parts bike' but would likely have no idea if their gear would fit your bike. If you could let us know that you are seeks a gear from any TW made between 1989 and 1995 then we could simply look on our Vin. tag and let you know we likely have a match. Just a thought. Gerry
    Take care my Friend.........
    Lower Rio Grande, New Mexico
    1,702
    Plus 1 to the Giz! Since parts don't come with numbers blazened on their surfaces, an annotated exploded diagram showing the part needed would help someone decide if they had such a beast. If its part of the kick starter addon, I don't have it, but if its on the motor side and engages the kickstarter, I probably do. Make it easy for us if you can. Tom
    Central New Mexico
    Ephrata, WA
    1,125
    Its number 5. Same thing for the TW.
    1990 TW200
    Paradise, Calif.
    3,514
    You're a great guy for doing that Rainman, but does that number get used on the TW, and for what years. My thought is the poster should do this search but if you are so inclined +1 again and my suggestion that you are a stand-out guy. I could as well, but am not inclined as I have lots of other stuff to take care of. Hope this fellow appreciates your effort. Gerry
    Ephrata, WA
    1,125
    Quote Originally Posted by mrgizmow View Post
    Glad to help out.
    Yes, the part does get used on the TW.
    Here is what I got.
    1990 TW200
    Paradise, Calif.
    3,514
    This is for being a NUMBER 1 standout guy... Good for you. Gerry
    Ephrata, WA
    1,125
    Thanks Gerry! I appreciate that.
    1990 TW200
    Jun 2012
    3
    Quote Originally Posted by Rainman View Post
    Thanks to all. Yes #5 is the part but actually all that is missing is the small gear on one side. Someone took it off for another bike. Too bad it is not sold separately.
    1,702
    I'm mailing off the part today. tom
    Central New Mexico
  1. what tool am i missing?
    By dutchbat in forum Technical Help
    Last Post: 06-02-2013, 12:28 PM
  2. Missing head gasket?
    By PalmStateCrawler in forum Off-Topic
    Last Post: 09-18-2012, 10:51 PM
  3. Missing some specs.
    By arbolmano in forum Technical Help
    Last Post: 04-04-2012, 07:33 PM
  4. If your tow strap suddenly goes missing.......
    By lizrdbrth in forum Off-Topic
    Last Post: 03-23-2012, 09:49 PM
  5. Missing bolts?
    Last Post: 09-06-2010, 02:19 PM
1982 yamaha xt200j
yamaha xt200j
