The black carby
Results 1 to 6 of 6
Thread: The black carby
    Junior Member RobRz's Avatar
    Jun 2012
    Sydney, Australia
    16
    Hi All
    I have a very strange carb problem with my 99 AG200, I just bought it and noticed black smoke when I rev it, it seems to run fine but I thought I better pull the carb apart and see whats going on in there.
    anyway on the air box side the throat was so black that it actually looked like the inside was painted black and when I rubbed it with my finger it felt like a painted surface? any way as soon as the carby cleaner hit it the black stuff it dissolved, it wasnt nearly as black on the engine side of the carb? very strange?
    so I rebuilt it and it seems to be running fine but still blowing black smoke with a black spark plug, any tips on leaning it out a bit or why it is black on the airbox side?
    also allot of grit and blackness down the intake port, I have a feeling that valve isnt sealing?
    cheers
    Rob
    Jun 2012
    Sydney, Australia
    16
    ok, I sorted out the rich mixture, previous owner put so much oil on the air filter it wouldn't let air through!!!! now I'm thinking this might be related to the black carby?
    Junior Member Scottbenson's Avatar
    Apr 2012
    Hooper Utah
    28
    Could be. Did the black smoke go away?
    Desert, SoCal
    7,369
    A stuck float will overfill the crankcase with gas/oil mixture when the bike is parked overnight which will in turn fill the airbox via the crankcase vent upon startup.
    It's possible that this occurred at some point in the bike's life and the airbox wasn't cleaned out afterward. Engine heat and time hardened the deposits.
    One possible explanation. Just make sure it isn't still going on. Your "over-oiled" air cleaner and black smoke are strong indicators.
    Jun 2012
    Sydney, Australia
    16
    Quote Originally Posted by Scott Benson View Post
    yeah mate, she runs clean now, a lil lean if anything I need to get a new carb joint, they are $69 bucks here in Australia and the o-ring is a whopping $18!!!!! we get stitched up over here.
    Jun 2012
    Sydney, Australia
    16
    wow,great point you make here,one I didn't consider,
    when I pulled the carb apart the bowl had allot of dirt in it so this is looking fairly likely.
    thanks for your input, much appreciated
    Rob
  1. Carby that can take boost? what to use?
    By MIK20B in forum Performance and Customization
    Last Post: 09-16-2012, 04:30 AM
  2. STI Black Diamond
    By flingwing1969 in forum Performance and Customization
    Last Post: 08-31-2012, 09:24 AM
  3. Anyone ride the Black Dog?
    By chipyting in forum Trails, Off-road, and Adventure Riding
    Last Post: 05-05-2012, 08:03 AM
  4. Black plastic
    By xdac in forum TW200 Classifieds
    Last Post: 02-02-2012, 07:31 PM
  5. Black plastic off a 2006 TW & Black seat cover
    By Mini-Mac in forum TW200 Classifieds
    Last Post: 11-06-2011, 12:32 PM
cleaning an ag200 carby
