idle help
Results 1 to 5 of 5
Thread: idle help
    Senior Member greendub's Avatar
    Montgomery, VT
    220
    Wondering if anyone else has experienced this. Bike idles correctly when i start it. After i ride and come to a stop idle is really high unless i crack the throttle, then it goes back to normal. Float height is correct. Enricher circut parts are new. old style carb 125 main 42 pilot 2.5 out and idle air 3 out. Plug light brown. Bike runs great at all rpm, slight high rpm miss at wot
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    Throttle cable hanging up/routed wrong or a little too tight?
    Aug 2011
    2,126
    dirty carb butterfly valve? Have throttle on full. a little carb spray and lightly clean valve and bore with old toothbrush.
    Montgomery, VT
    220
    new cable, no hang ups, Fully cleaned, dissasembled taken apart and soaked a month ago. What do you mean butterfly valve
    Montgomery, VT
    220
    if you look at the throttle it is sitting right on the idle screw. so the throttle is all the way off
  1. 91 TW 200 will idle, then die out
    By aduboisiii in forum Technical Help
    Last Post: 07-17-2012, 06:28 PM
  2. Dealing with idle TW?
    By drs6222 in forum General Discussion
    Last Post: 04-26-2012, 06:40 AM
  3. idle speed
    By mike m in forum Technical Help
    Last Post: 01-29-2012, 05:58 PM
  4. Fast Idle
    By ezman671 in forum Technical Help
    Last Post: 10-25-2011, 07:34 PM
  5. Return to idle...
    By Jerry Lee in forum Technical Help
    Last Post: 08-27-2010, 10:44 PM
