Light problem.
Results 1 to 3 of 3
Thread: Light problem.
    Junior Member bryns93tw200's Avatar
    14
    When I start my tw, the lights kinda flicker which I guess isnt abnormal but when throttled up going down the road the lights go dimmer. Most bikes the higher the rpm the brighter the lights get. Mines the opposite. Any ideas?
    Ephrata, WA
    1,125
    What year, how many miles on it, and how long have you had it?
    1990 TW200
    Desert, SoCal
    7,369
    Classic symptoms of a shorted cell in the battery. Do the checks by the book and replace it if need be.
  1. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 08:36 PM
  2. A problem with my new TW
    Last Post: 12-09-2012, 05:22 AM
  3. Carbuertor problem
    By aduboisiii in forum Technical Help
    Last Post: 07-25-2012, 04:11 AM
  4. I think I have a problem
    By n2o2diver in forum General Discussion
    Last Post: 12-20-2011, 06:16 AM
  5. Front Signal Light Problem 09TW
    By cacosta in forum Technical Help
    Last Post: 05-13-2011, 05:17 PM
