What do you use to support your TW for work?
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Like Tree1Likes
Thread: What do you use to support your TW for work?
    1993 TW200 in Meridian, Idaho
    1,533
    I wanted to pull off my front wheel to check my brakes. (Drum brakes on a '93). I tried a plastic 5-gallon bucket, but the TW crushed it like a walnut. I went to Cycle Gear and bought a lift support. (The kind you step on a pedal to lift the bike.)
    First, the lift was still too tall even in the down position to slip under the engine area. Tipping the bike on the sidestand I was able to get the lift under it. In the down position, the tires just were resting lightly on the ground, still not up enough to pull the front tire easily.
    Trying to step on the pedal to raise the bike was impossible. The pedal angle was way up there and there was no way my weight, (fortunately less that the TW) was gonna push down the pedal. Fooling around with it, I did take enough weight off the stand to raise the bike, and then found it precariously high and unstable. I'm guessing this stand might work for dirtbikes where the ground clearance is higher to start with go that the stand slips under without touching in the down position. It's just not gonna work for the TW and I'd never feel safe with it perched there. I hope Cycle Gear will take it back, even though it's now scuffed up pretty well.
    What do you folks use when you want to get both wheels off the ground for working on your TW? And...is this setup something one person can get the bike on and off?
    Desert, SoCal
    7,369
    I prefer this type for general maintenence at home. I use a crutch jack for flat tires and chain lubing in the field. They're quite stable and some of them have rigs for tiedowns if yer a worry wart. Full on bike tables are tempting, but they always seemed more nuisance than they're worth except when doing long-term builds:
    http://www.autobodytoolmart.com/craf...FWQ0Qgod-kQzMg
    Sep 2011
    Southcoast MAsshole
    2,661
    i have this...but i roll the rear tire onto a couple boards next to the stand and stand on the board to lift it onto the stand (see the photo for the board and stand)...min. height is 13.75"...max. height is 35.5"...i've used a milk crate with a piece of plywood on it as well...
    http://www.gregsmithequipment.com/Motorcycle-Lifts
    if i didn't want to lift it i think i would go with this...not positive if the 13" max height would be enough of a lift though...
    http://www.klsupply.com/JACKSANDSTAN...JACKDOLLY.aspx
    http://www.motorcycle-superstore.com...nter-Jack.aspx
    Hidebound likes this.
    Lower Rio Grande, New Mexico
    1,702
    If you have the space to store it when not in use, the HF motorcycle jack (lift) is a reasonable alternative for the TW.
    I bought this one http://www.harborfreight.com/1500-lb...lift-2792.html, but I believe they have a more deluxe model. The price is right and it works (after I added a plywood base for the existing struts. Tom
    Central New Mexico
    Desert, SoCal
    7,369
    That's the same unit I have. They're sold under every imaginable banner from Harbor Freight to Sears to high end labels and painted various colors to suit, but they're all identical and made in China.
    I bought two at Pep Boys under the "Torin Big Red" brand for half the HF price, so it pays to shop around.
    The arms are even long enough to span the lower frame rails of my Goldwing and Concours, yet not so long that they hit the pipes, or so long that they interfere while working on the TW.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    That's the same unit I have. ...
    I have two, a red and yellow.... the Harbor Freight version. I put a piece of 1/4" plywood on the arms to distribute the weight of the bike on the skid plate.
    It rolls easily under the bike, and takes only a few seconds to jack the wheels off the ground. I use it at the end of each day's ride to lube the chain.
    There's usually a HF coupon in one of the cycle magazines for a discount on the lift.
    The HF 20% off coupon is no longer allowed to be used for purchase of lifts.
    jb
    In a pinch, highside over a log.
    I have a HF table lift. Roll the bike up, strap one end, jack it up, small floor jack under the engine, raise the other end, strap second end, loosen original straps. Any lift without straps is asking for trouble when both tires are off the ground.
    1,533
    Looking at your photo below... How is it the bike continues to balance on the stand with the front wheel (or back wheel) off? Using the stand I tried from Cycle Gear, there was no way the bike was going to balance on the stand with a wheel off. This looks like and accident waiting to happen.
    The more I think about it, the better I'm liking the milk crate idea. Dirt cheap, simple to store, and stable. I don't work on my bike that often so I want to do this "on the cheap." The Cycle Gear Stand was $26.00 on sale and that was great... had it worked...
    Member BuddyMc's Avatar
    Huntsville, AL
    99
    Quote Originally Posted by Truelight View Post
    I sold my Cycle Gear dirt-bike lever lift with my KTM mainly because I already knew the thing was too tall for the TW I was getting to replace the KTM. My TW solution is the cheap $20 lift from Harbor Freight, which is also too tall. I simply shortened the two main square tubes by 4 inches each. Since that action removed the attachment point for the lift lever, I cobbled up a clamp around the outside of the tube to attach the lift lever. It was also necessary to add some "feet" to the lift body to give the lift lever room to pivot to the full lock position. For $20 plus $3 for the clamp materials it works just fine! If you weld, it would be real easy to simply relocate the original attachment point.
    My TW Riding Buddy uses a Bulldog (think that is the brand) axle lift from Cycle Gear which picks the bike up at the axles and seems solid when is use. It was also $70, which was w - a - a - a - y more than I was willing to shell out.
    Good luck.
    Huntsville, Alabama - Have TW, Will Ride! All White 09 TW, D2Moto Pegs, Bridgestone 302 front tire, 2" higher bars, 3/4" fork preload spacer, 5wt Honda fork oil, 135mm fork oil level, exhaust tip mod, 2.5 turns out fuel mixture, 0.060 in needle shims, 130 main jet, 14/47 sprockets, 20w-50 Valvoline MC full synthetic oil, ImmixRacing rear rack, Bilt Bag on Rack, 1" front fender spacers, Battery Tender connections on new battery (installed 12/11), Coleman ATV seat cushion, 2 Agri Supply tool tubes, 30oz MSR Fuel Bottle, auxiliary 6 LED tail light, Sylvania Silverstar Ultra H4 headlight bulb, 2357 turn signals, and Superbright's 1157 LED Motorcycle Tail Light Bulb with 19 red & 6 white LEDs. Shortened rear turn signals. Bypassed kickstand switch.
    Plus a "new to me" 1995 Yamaha Virago XV 750G for Pavement Purposes!!
    Aug 2011
    Cayce, SC
    3,109
    Milk crate and 2x4s is what I use. Just pulled up behing bi-lo (or any other grocery store) and strapped it to the rack. It's not the most elegant solution but it gets the job done. Maybe one day i'll splurge for one of those lifts but probably not until I get a 4wheeler.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
  1. Cyclerack bag support - help?
    By thal13 in forum Performance and Customization
    Last Post: 04-06-2013, 02:21 PM
  2. First ride to work......
    By kenfyoozed in forum General Discussion
    Last Post: 09-28-2012, 12:51 PM
  3. Can't get right after Carb work
    By SURVEYWATERS in forum Technical Help
    Last Post: 03-29-2012, 03:49 PM
  4. TW 125 work in progress
    By Mame Shiba in forum Performance and Customization
    Last Post: 02-20-2012, 11:33 AM
  5. Carb Work
    By jakemistake in forum Performance and Customization
    Last Post: 07-29-2010, 06:51 AM
best lift for tw200
cyclegear stand triumph bonneville
how to drill tw 200 rear shock swing arm hole
