1990 carb Question
Results 1 to 3 of 3
    Member Gene-st1300's Avatar
    Aug 2011
    42
    What is the purpose of the diaphram on the left side of the carb? and when it goes bad could it cause a very rich running condition ?
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,389
    Quote Originally Posted by Gene View Post
    I don't have the carb in front of me, but I believe the part you are referring to is part of the "coaster circuit". That's what Yamaha calls it, there may be other names for it.
    It provides an extra bit of fuel when the throttle is quickly closed... that extra fuel helps prevent backfiring.
    If the diaphragm is damaged, the fuel is provided continuously which could lead to a rich condition. However, the hole where this extra fuel enters the carb throat is so small, I suspect it's not a great amount of extra fuel.
    jb
    Aug 2011
    42
    So to eliminate this for test reasons all all need to do is pinch it off in the middle and see how it does , thanks
  1. 1990 headlight question
    By Bizz in forum Technical Help
    Last Post: 06-19-2013, 10:55 PM
  2. 2010 Carb question
    By RockyTFS in forum Technical Help
    Last Post: 03-26-2011, 11:31 AM
  3. 1990 TW 200 Carb Vent lines?
    By sasnydley in forum Technical Help
    Last Post: 03-15-2011, 07:00 AM
  4. Cleaned Carb, now I have a question
    By Quicksand in forum Technical Help
    Last Post: 08-16-2010, 06:15 AM
  5. Carb question...
    By adavis in forum Technical Help
    Last Post: 08-12-2010, 08:57 AM
tw200 forum 1990 carb
