leaking smurf
Results 1 to 7 of 7
Thread: leaking smurf
    Junior Member mattzuki's Avatar
    Jun 2012
    Knoxville TN
    16
    I changed the oil and filter out on my new to me 1989 smurf(intro-ed here) last Saturday.
    Rode it pretty good off road then noticed a leak that appears to be coming from the cam sprocket cover on the cylinder head.
    So I am trying to decide how far to go with this.
    "Don't fix what isn't broke" vs "ounce of prevention..." kind of dilemma.
    I am thinking I will go with a Athena Complete Engine Gasket Kit from bike bandit, and just replace the one leak-er now and have the others ready to go when problem encountered.
    So questions-
    Does this seem like a reasonable strategy or should I just bite the bullet and replace them all?
    Does anyone have experience with this particular gasket kit or any other to share?
    Ephrata, WA
    1,125
    Mine did that so I replaced it and the leaked stopped. Its just a simple o-ring. My tappet covers leaked as well and new o-rings solved the issue. I wouldn't replace all the gaskets, I'd just do the ones that leak.
    1990 TW200
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by Rainman View Post
    Rainmans' right!....why do everything,unless you REALLY want too?.
    Senior Member Ayers Garage's Avatar
    Jun 2012
    125
    The o-ring is Yamaha part number 93211-05471-00. Price is 4.94. Add 1.75 for shipping. You're under 7 bucks total and you have genuine Yamaha parts.
    The parts fiche.You want part number 13.
    http://www.powersportsplus.com/parts...EAD/parts.html
    The specific part detail
    http://www.powersportsplus.com/parts...-05471-00.html
    Jun 2012
    Knoxville TN
    16
    Thanks for the advice. Want ride it more than work on it. I am just going with the single O-ring for now. Went with powersports too good price and cheap shipping.
    Jun 2012
    125
    When I'm restoring a bike, I order at least weekly from them. They can sometimes take a few days to receive the parts from the manufacturer and then get them shipped to you, but they have a real good system where you can watch your order and see the parts arrive and get added to the roster before shipping. I only use OEM parts when possible and no one can beat them for pricing and service.
    Ephrata, WA
    1,125
    I have a 1990. It hasn't nickeled and dimed me, but I have found things that break or leak or both. I just replace them as needed. An older bike with few miles is still an older bike. Gaskets dry up, o-rings leak, bearings lose grease, etc.
    Theres even times I'll order some parts only to find out that after replacing those parts something else leaks/squeaks/breaks and I'll have to replace it too. Don't let it discourage you.
    1990 TW200
  1. bowl leaking
    By Jassenk in forum Technical Help
    Last Post: 05-08-2013, 09:04 PM
  2. Smurf's Up! 1989 barn find
    By SURVEYWATERS in forum General Discussion
    Last Post: 03-26-2012, 08:59 PM
  3. Carb Leaking
    By scbydo in forum Technical Help
    Last Post: 07-22-2011, 03:17 PM
  4. Gas Leaking from Carb
    By lrotunda in forum Technical Help
    Last Post: 05-02-2011, 10:22 PM
  5. Gas leaking into air box overfill
    By Adam-n-nevada in forum Technical Help
    Last Post: 08-21-2010, 09:47 PM
