New clutch cable = NICE!
Results 1 to 7 of 7
    Senior Member darnold87's Avatar
    Salem, OR
    908
    After loving my new front brake cable, I decided I'd replace the clutch cable. It was only $17 from 'Motion Pro' (ordered through local bike shop). Install was easy. I found this new cable to be easier to dial in our sometimes finicky clutch adjustment. The smoothness of this new cable is great. Just thought I'd mention this, since this quick upgrade cured my 2+ years of questionable clutch adjustment...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Member -Jake-'s Avatar
    Feb 2012
    81
    Quote Originally Posted by darnold87 View Post
    I've always just pumped loads of liquid graphite in them. A new one does sound cheap enough though...
    Ephrata, WA
    1,125
    Awesome! You never know how bad your cables are until you get a new one! I noticed the same thing when I replaced my clutch as well as my brake cable.
    1990 TW200
    Salem, OR
    908
    Yes, comparing the ease of cable movement through the housing of the old vs new cables was amazing. I was kind of surprised my brake and clutch cable even worked properly. I love that the new cables allow my control levers to completely spring-back into open position. The old cables just had too much drag...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Jul 2012
    Wet-ern Washington
    1,404
    What would be the differences/advantages to the Motion Pro cable? Cost seems very similar to the OEM, so why one over the other?
    - Leisure Time Larry -
    2004 TW200, 13-54 gearing, Shinko 241, Race Tech Emulators, Procycle front springs, Works Performance rear shock, Emgo handguards, Luckybike mirror risers, Ken Sean DS foldable mirrors, 30mm Tusk bar risers, Seat Concepts, Kick Starter kit, Plasti-dip camo coat, Cycle Pumps, Ricochet Skid Plate, flood and spot LED pod lights, Sena, Garmin etrex 20 GPS, IMS 313114folding shifter
    Salem, OR
    908
    I usually go OEM, but didn't specify when I ordered the cable. Either one is fine. But id go OEM, especially since the price is close.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Junior Member Adam38654's Avatar
    Jul 2012
    14
    I think motion pro cables have a nylon inner sleeve for smoother operation. Lubing older ones works well also.
  1. Tusk D-Flex and Clutch Cable Clearance on Pro Taper Hi-ATV
    By retmotor in forum Performance and Customization
    Last Post: 07-25-2017, 12:16 PM
  2. Clutch Engagement vs Free play in clutch lever
    By Jay-2 in forum Technical Help
    Last Post: 04-09-2014, 06:24 AM
  3. Replies: 2
    Last Post: 05-28-2013, 11:00 AM
  4. Clutch Cable Measurement?
    By SpudRider in forum Technical Help
    Last Post: 08-06-2012, 11:21 PM
  5. Nice graphics don't pay
    By Rohnsman in forum Technical Help
    Last Post: 09-29-2010, 09:23 PM
motion pro vs tusk clutch cable
tusk vs motion pro cables
