Carb cleaning for dummies
Results 1 to 10 of 15
    Junior Member Whippet's Avatar
    Sep 2010
    12
    So I bought a 2004 TW about 4 months ago. It had about 800 miles on it when I bought it and now has 1500 miles. It seemed to run fine in the beginning and now idles poorly, hesitates on the top end, and leaks gas out of the carb hose. I ran a tank of carb cleaner. No real improvement. The air filter is clean. The air filter hose had some oil in it. From what I have read on forums and such I'm guessing the problem is a "stuck float"..not really sure what that means..or a petcock problem...you get the picture. I've heard these terms pointing me in this direction, but I don't know where to go from here. Should I run another tank of carb cleaner, "try" and disassemble and clean...will I know what to replace when I see it?, or take it to a mechanic? My experience with mechanics is that they "see me coming" and take me to the cleaners. I'd like to get to know the basics of service and repair but...
    I know nothing when it comes to fixing stuff...I'm a master take-it-aparter, but then I just look at it and don't know what to look for. Putting it back together is always a challenge so I have not attempted with the TW.
    Any suggestions or diagnoses? I'm in SLC, UT if anyone knows of an "honest" mechanic.
    Thanks in advance for any help.
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    Don't really know how to answer. If you're not sure you want to tackle the carb, then maybe you shouldn't. That said it's not the most difficult thing to remove and clean. Get a carb kit, follow the repair manual - there lots of useful info if you search for it. Putting it back together right is most important. Before you rip into the carb investigate some other possibilites first:
    When you say it leaks gas out of the carb hose, which one and where - is it just a weak hose clamp?
    Idling problem are not usually related to a stuck float - that usually manifests as a fuel dumping problem on acceleration or a lack of fuel acceleration (hesitation).
    Take the spark plug out and look at it - is it nice tan brown like it should be? Or wet or sooty? That helps diagnose issues with the fuel input.
    How about the lean/rich fuel mixture screw that is hidden behind a brass cap that Yamaha puts on to prevent us from messing it (emissions issues). Search the old forum for how to remove the plug and adjust the screw.
    Did you try Seafoam in the gas tank? I have had good success with Seafoam on my older bikes.
    Regards...Wes
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Wes has some good suggestions.
    I'd try the Seafoam first (available at Walmart or most auto parts stores), and hope that works.
    The usual amount of Seafoam to add is one ounce per gallon for preventive maintenance. For a clogged up carb, I use half a can (8 oz) per tank (1.7 gal).
    It takes some time for Seafoam to do its work. Run the engine 5 min.,then let it sit for 20-30 min, then repeat. Or if the bike is running, go for a ride. Do the same thing for a couple days, and see if there is any improvement.
    If not......... this is what you are up against:
    I'm certainly no expert, but have taken apart and cleaned my carb more times than I care to. My bike sits for several months at a time, and when I forget to drain the carb before storage, it's time to take it apart again.
    For me the culprit is the float valve needle, part 25, the bottom part in the above diagram. To get to it the float needs to be removed.... very carefully.
    However, this may not be your carb's problem...For me carb work is a lot of trial and error.
    If you are not comfortable doing that, call or go in to your Yamaha dealer, or independent, and ask how much it would cost to clean and adjust your carb. You can always say no.
    Next time I clean my carb I will try to remember to take photos... although I hope it won't be too soon.
    Good luck.
    jb
    FL. GA, NC
    2,396
    Here's a article about using Seafoam in a motorcycle:
    Seafoam Article from WebBikeworld
    You can tell it's an old article, the author bought a can of Seafoam for $2.99. These days it's closer to $9.
    There are some naysayers about the Seafoam's effectiveness. My experience with it has been positive.
    jb
    Sep 2010
    12
    I put some Lucas in today and ran 1/2 tank. It seems to be doing much better performance wise. I think I'll run this tank out tomorrow then put in some Seafoam and see how that goes.
    Thanks for the advice guys!
    Senior Member Snake2715's Avatar
    Aug 2010
    166
    Let us know how it turns out.
    I have a question and dont want to hijack, but that pic is great help.
    Does anyone know if we have a sticky or thread that covers the basics on the carb?
    In looking at two bikes I noticed that the older one my buddy is looking at, has a cap on the rubber boot between the carb and head... I am confused as to where that hose goes, as I can see it go under the gas tank on my bike.
    Also I want to look into adjusting the possible lean ness of the bike as well due to the many people saying they come way too lean from the factory.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by Snake2715 View Post
    I believe we found that the hose is called a "resonator" somewhere. It just goes up and terminates under the tank, not connected to anything.
    A hose between the carb & cylinder would have vacuum. Maybe the engineers were originally thinking of using a vacuum shut-off on the fuel petcock. Like my '80 850 had.
    Stephen S.
    '07 TW200:
    Sep 2010
    12
    I had a friend take the carb out and clean it. He said I had a "really big main jet". I didn't get the number off it before he put it back together unfortunately. The carb itself looked very clean inside, but there was crud sticking in the float needle. It ran really well in the valley at 4000-5000 ft elevation. I took it up the canyon and it had issues (lack of power, stalling, hesitating) again at 7,000 ft and higher. Seemed to run better again in the valley. I commuted the other day and left the gas line very slightly past closed toward reserve and came back to a puddle of gas. I barely got it started and barely made it home. Stalling, etc. Let it sit a few days and took it for a spin today to run into the same issues down in the valley. I made it home, but now it sits again. I took out the spark plug...not sure why...just to "see". It's only about a 100 miles old and it was dry and black. Is that "normal" or is this is clue?
    Have I narrowed down the problem? I willing to go to a mechanic now, but I'd still like to have a good idea of the potential problem.
    Thanks again for the suggestions.
    Member migopod's Avatar
    Sep 2010
    MKE, WI
    32
    Dry black plugs indicate an overly rich mixture. Going from easy to not as easy, check your air filter. A dirty air filter reduces the airflow and leads to a mix too rich in fuel. Then check the carb main jet size against the stock part. You might wind up wanting to do that anyhow, since the puddle of gas suggests your float valve is crudded again or that your friend mis-set the float height when doing you carb before. Also if your float valve is re-crudded, you'll probably want to get an inline fuel filter to prevent it from happening again.
    1976 cb550f SuperSport, 2010 tw200
    Entia non sunt multiplicanda praeter necessitatem
    ^[:wq
    The stock main jet on a 2004 is a 125 if a 49-state model or a 128 if a California "C" model. A 132 is also available. If you are riding at 5000 to 7000 feet or higher you'll want the 125 jet as altitude causes a richer mixture. You may find E10 works better than straight gasoline with your black plug at 7000 feet.
    p.s.: If your carb is leaking while sitting it is messed up. The only times I turn Tdub's petcock off is when I'm removing the tank or hauling her somewhere. Otherwise, she never leaks a drop.
  1. Lazy Man's Carb Cleaning Questions
    By Avi Kwame in forum Technical Help
    Last Post: 04-09-2013, 07:06 PM
  2. CLEANING
    By dutchbat in forum Performance and Customization
    Last Post: 01-08-2013, 09:10 AM
  3. carb cleaning
    By phelonius in forum Technical Help
    Last Post: 01-29-2012, 12:24 PM
  4. Carb cleaning for dummies
    By Whippet in forum Technical Help
    Last Post: 04-07-2011, 09:18 PM
  5. Lazy Man's Teikei (TK) Carb Cleaning
    By jbfla in forum Technical Write-Ups
    Last Post: 12-08-2010, 10:48 PM
dr 200 carb leaking
how to clean carborator 1987yamaha tw200
how to clean carburetor on yamaha tw200
how to clean the carb on a tw200
how to clean the fuel filter on a yamaha tw200
how to remove carberator yamaha tw200
tw200 carb cleaning
tw200 carb cleaning for dummies
tw200 carb removal
tw200 carburetor cleaning
tw200 how to remove
yamaha tw 200 carb cleaning
