Just found this in my Carb
Results 1 to 8 of 8
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    I just found this gasket covered in corrosion at the float bowl. The float bowl area itself was immaculate. It looked brand new inside, what I am wondering is if this gasket could be the cause of the inconsistency I have seen in the way my engine runs.
    Or should I keep looking at the carb (I ask this because I can't seem to get the float off.)
    The corrosion covers all sides.
    -Szj
    2001 TW
    Member -Jake-'s Avatar
    Feb 2012
    81
    I'd keep digging. If it wasn't leaking gas then I'd say the gasket isn't your issue.
    Member BuddyMc's Avatar
    Huntsville, AL
    99
    Be sure to follow the manual / and the supplement's guidance as to dis-assembly. The pins that hold the float mechanism in place is pretty fragile and will easily break the carb body if not handled properly. Down load the manual and supplement. Print them if necessary. Get the carb working in stock form before you start "improving it". Lot's of pinned instructions with PICTURES on carb work, so read and head the advice.
    Huntsville, Alabama - Have TW, Will Ride! All White 09 TW, D2Moto Pegs, Bridgestone 302 front tire, 2" higher bars, 3/4" fork preload spacer, 5wt Honda fork oil, 135mm fork oil level, exhaust tip mod, 2.5 turns out fuel mixture, 0.060 in needle shims, 130 main jet, 14/47 sprockets, 20w-50 Valvoline MC full synthetic oil, ImmixRacing rear rack, Bilt Bag on Rack, 1" front fender spacers, Battery Tender connections on new battery (installed 12/11), Coleman ATV seat cushion, 2 Agri Supply tool tubes, 30oz MSR Fuel Bottle, auxiliary 6 LED tail light, Sylvania Silverstar Ultra H4 headlight bulb, 2357 turn signals, and Superbright's 1157 LED Motorcycle Tail Light Bulb with 19 red & 6 white LEDs. Shortened rear turn signals. Bypassed kickstand switch.
    Plus a "new to me" 1995 Yamaha Virago XV 750G for Pavement Purposes!!
    Senior Member kennethshaw's Avatar
    Jan 2011
    170
    Something that has always worked for me to get that pin out is automatic center punch. You can buy one at harbor freight for 3 bucks right now. Just make sure you are pushing the pin out the right direction.
    http://www.harborfreight.com/spring-...punch-621.html
    Tennessee
    1,286
    Yeah, the pin on this carb seems to come out one way much easier than the other. And definitely be gentle to avoid breaking the posts. I use a tiny allen wrench and just push through.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,392
    Quote Originally Posted by Sweetzombiejesus View Post
    ...(I ask this because I can't seem to get the float off.)
    This might help you remove the float:
    https://tw200forum.com/index.php?/top...buretor-float/
    I would replace the gasket even if it wasn't leaking. It may not seal when you reassemble the carb.
    The gasket should look like this. Make sure the flat side with the ridge is facing up,
    jb
    Member Robert Ibe's Avatar
    Mar 2011
    30
    I dont think thats corrosion on the gasket, its more likly a mixture of varnish and the crap that precipitates out of todays gas and it was probably keeping the bowl from leaking.
    If you decide to do a carb dip be aware there is a rubber seal on the controle arm end of the butterfly shaft and a plastic bushing on the other plugged end that will need to be removed before dipping or they will be destroyed, these parts are not shown on any of the parts diagrams I,ve seen.
    Robert
    Senior Member darnold87's Avatar
    Salem, OR
    908
    Check your carb vent tubes.
    I've seen two TW200's have issues because of this:
    My buddie's had a plugged tube and caused it to start leaking fuel out of the carb.
    Mine just recently had a plugged tube and started starving it on medium to heavy throttle, causing erratic popping and surging. Easy check. And since our bikes are low, mud and debris can easilly plug the vent tubes since they hang down by the swing arm...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
  1. I found a 91, but I think the guy is nuts...
    By Tom Bettiker in forum General Discussion
    Last Post: 04-09-2013, 08:02 PM
  2. (FOUND ONE) WTB: 126 main jet for an 06
    By koonercat in forum TW200 Classifieds
    Last Post: 07-29-2012, 08:35 AM
  3. WTB: TW Seat or Pan ( I found one,THANKS)
    Last Post: 06-05-2012, 07:11 PM
  4. Just found the new forum...
    By idahoblueskies in forum General Discussion
    Last Post: 08-18-2011, 09:37 AM
  5. I think I found my bike
    By invisibledove in forum General Discussion
    Last Post: 03-01-2011, 05:58 PM
