Clarke Tank Fit
Results 1 to 3 of 3
Thread: Clarke Tank Fit
    Member ldw72120's Avatar
    Oct 2011
    Central Arkansas
    69
    I bought 2 of the tanks for a TW200 during the April promotion and got around to installing them today. I've read on here before about the right side panel not clipping into the tank and that is the case on both of these tanks. I did a search but was unable to find the fix to make the panels fit. Anyone point me in the right direction?
    Senior Member mekdad's Avatar
    Jan 2012
    idaho
    189
    I heated mine with a heat gun and streched them out. Go farther than you need it will contract when it cools.
    You never know what you can do until you have to undo something you have done.
    Apr 2011
    Martinsville Indiana
    2,089
    Mine didnt fit when i first got it. The tank expands a little bit after use. I rode mine to work a few times and let it sit in the sun a few days. I drilled a small hole next to the nipple and zip tied it until it expanded. I didnt want to cut off the nipple and drill a hole through the plastic panel like some did. Good luck
  1. Clarke tank for TW200
    By Purple People Eater in forum Performance and Customization
    Last Post: 08-17-2019, 08:52 AM
  2. Got that Clarke XT350 tank on!
    By DonBenito in forum Performance and Customization
    Last Post: 02-22-2013, 05:43 PM
  3. clarke gas tank
    By phazer in forum Technical Help
    Last Post: 12-26-2011, 09:17 PM
  4. Clarke Fuel Tank
    By HenryJ in forum Performance and Customization
    Last Post: 06-24-2011, 09:58 AM
  5. Clarke four gallon tank
    By TK200 in forum General Discussion
    Last Post: 02-07-2011, 06:53 PM
